is a camber kit necessary?
Old Jun 11, 2009 | 05:24 PM
mcd's Avatar
mcd
Default is a camber kit necessary?
I currently have Tein H-tech springs on my car and am planning on installing the Tociko shocks and struts. I'm wondering if it would be a good idea to also get a camber kit to help prevent uneven tread wear. If so.. what is a good quality but still relatively reasonably priced camber kit?
THANKS!
-mcd
Old Jun 11, 2009 | 05:27 PM
ack154's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=105012
Old Jun 11, 2009 | 05:41 PM
mcd's Avatar
mcd
i'll take that as a no i suppose. wonder why my toyo proxe 4's are bald after one year then.
Old Jun 11, 2009 | 07:21 PM
XIEmperorIX's Avatar
Did you get an alignment after you were lowered? rotate your tires regularly? how many miles did you drive in a year?
The answer to those question will probably tell you why your proxes are worn so low already.
Old Jun 11, 2009 | 09:26 PM
mcd's Avatar
mcd
I just want to prevent uneven wear. So I should be fine with just the springs and shocks & struts?
Old Jun 12, 2009 | 01:13 AM
As long as you have a proper alignment, regularly check your tire pressure, and rotate your tires when it is needed then you will be fine.
Old Jun 12, 2009 | 01:20 AM
iheartzombies's Avatar
I am slammed on B&G coilovers. I mean SLAMMED.
The sears auto place was able to get me around -1 camber with the stock adjustors, and they fixed my toe.
Been going for a while now and my tires are wearing fine.
jcraff3
Feb 20, 2015 11:41 PM
kleecker
Jan 2, 2015 08:09 PM
Alvie
Dec 12, 2014 05:04 AM
Mr_Magu
Jan 17, 2004 05:21 AM
randode
10
Dec 11, 2003 06:05 PM
