Wideband during 2step launch
Old Jun 15, 2009 | 02:01 PM
rhythmnsmoke's Avatar
Music City Scions
Default Wideband during 2step launch
I wondered if anyone that's tuned on a 2step (be it WOT Box, Ultimate, or Standalone), ever paid attention to what their Wideband was reading during the 2step engagement? What A/F ratio is it reading during the 2step, also if you are pulling timing during the 2step, do you know how much.
I'm trying to get my Ultimate tweaked to be safe to run the 2step at 4k rpms.
Also, if you have the 2step setup on the Ultimate, what number are you using for the V.S. Pulse that detects when the car is moving so it will cancel the 2step. I have it set to 4 which is what I recall it suppose to be for the tC.
Old Jun 15, 2009 | 02:15 PM
Ace83's Avatar
Ronin Scion
should be same afrs as you boost afr on you map but depends on how you tune it, i will log my 2 step again when i get a change and see the difference in ignition
Old Jun 15, 2009 | 02:34 PM
Music City Scions
Ok, right now my map is zero'ed out (no tune yet), so it's what the factory ECU is. I'm going to have to do a map trace and find out what cell the 2step falls into, and then richen it up. I think right now it's super lean when it engages (since the wideband goes "-----" when I hit the 2step).
More input much appreciated.
Elevation? What about you?
Old Jun 15, 2009 | 02:41 PM
Ace83's Avatar
Ronin Scion
oh yeah i forgot you na for now.. maybe a good target for you would be 12.6-13, i dont know how the ultimate manages 2 step but check if you are not removing too much fuel from your base fuel
Old Jun 15, 2009 | 02:46 PM
Music City Scions
Yeah N/A blows! But have to take a step back to take 2 steps forward. I'm going to play around with it today.
So, your Wideband still reads the A/F ratio even during the 2step? And doesn't go "----"?
Old Jun 15, 2009 | 02:54 PM
Ace83's Avatar
Ronin Scion
yeah its shouldnt read as lean as that.. i think it would stall if you launch on very lean afr since there is not enough power to get the car running.. when i had some messed up values on my antilag map my afrs are like 15s and it barely builds boost
Old Jun 15, 2009 | 03:25 PM
Music City Scions
Yep, you got it. Tried a launch at 3500rpm's and it just feel on it's face and stalled. Didn't shut off, but it booged all the way down to that point.
Old Jun 15, 2009 | 03:38 PM
ElevationTC's Avatar
OK OK..
3500 is weak! Period! lol
i run mine very rich at two step! alot of ____ going on there so i make it around 10.5-11.00 afr
i set two step around 5k this has proven to be perfect launch spot for my car..
peep the attached image for the way its setup in aem pro
Old Jun 15, 2009 | 04:17 PM
Music City Scions
Originally Posted by ElevationTC
OK OK..
i run mine very rich at two step! alot of poop going on there so i make it around 10.5-11.00 afr
5k rpm would cause me to go no where....LOL. I don't have slicks yet bro, but when I do, I'll have it set to something that high.
PS...Anyway to make that screen shot a little larger? Thanks for the screen shot by the way.
Old Jun 15, 2009 | 04:35 PM
OK OK..
sure or just dl the aem pro software from aempower.com/forums and ill send "you" the map! Not to be shared.
No slicks = no two step trust me!
so set it to 5k to show people dont ____ with you.. but dont use it! ull just spin on any street tire
Old Jun 15, 2009 | 05:18 PM
paul_dezod's Avatar
Scionetics
KAD
OK OK..
Yeah 2Step retards the timing AND floods the engine with fuel. These 2 factors SKY-ROCKET the EGTs, which in turn helps the turbocharger spool incredibly fast.
Old Jun 15, 2009 | 05:31 PM
OK OK..
But gotta give it to paul because without him i would be rollin with the "fic"
Old Jun 15, 2009 | 06:19 PM
paul_dezod's Avatar
Scionetics
KAD
Thank you sir!!!! Instead you are spanking plenty of cars with your standalone turbo'd tC!
Old Jun 15, 2009 | 06:22 PM
did you see my youtube vids paul?
http://www.youtube.com/watch?v=Sf9KS...e=channel_page
check them out!
Old Jun 15, 2009 | 06:31 PM
CarbonXe's Avatar
Just curious Travis, but why are you running a two-step? Aren't you setting up for TA?
Old Jun 15, 2009 | 06:34 PM
He's secretly in a race with meh
jk jk
Im sure its just one of those.. if i have it let me use it!
Old Jun 15, 2009 | 06:41 PM
paul_dezod's Avatar
Scionetics
KAD
check them out!
I just checked them out. Nice.
Old Jun 15, 2009 | 08:00 PM
Music City Scions
so set it to 5k to show people dont flip with you.. but dont use it! ull just spin on any street tire
Yeah, I mean I have Drag radials so I'm not terribly off. But yeah, the 2step is also going to serve a purpose for the smuck who wants to rev on me or something at a stop light. Just tap it a little and then smile back.
Old Jun 15, 2009 | 08:04 PM
trust me.. it works veryy well! Mine sounds like a 357 mag going off! people usually dont try after i hit the 2 step!
Old Jun 15, 2009 | 08:21 PM
Music City Scions
jk jk
Time Attack is priority #1. BUT.....I drag and AutoX while waiting for the Time Attack events to get here. I have to fill that itch to race something. So, the 1/8th mile track is closest thing, and its opened every weekend. Auto X is every other weekend, and Time Attack days are about a month apart. I can't wait that damn long to smash the gas. So, got to do something....
And yeah, if you got it, and your a racer....who the hell wouldn't set it up, even if it was just for the cool factor.....lol.
