question about my s-pipe
Old Jun 23, 2009 | 11:25 PM
krazyjvilled's Avatar
Default question about my s-pipe
i have ordered an invidia s-pipe and i went out today to check my stock one, which i thought was supposed to be just bolted on, and i find that appears to be welded to my midpipe... is this the case? if not, how do i go about getting off my stock s-pipe?
Old Jun 23, 2009 | 11:38 PM
daffy12's Avatar
its not welded on. there two bolts connecting it to the header and two bolts connecting to the midpipe. theyre both size 9/16 i believe. other than that you have the o2 sensor you need to remove which is a 15/16 size.
just take those off and put the new one. no welding anywhere...
Old Jun 23, 2009 | 11:52 PM
oh ok great thanks, i cant even really get under there... ill just have to jack it up i guess. thanks
Old Jun 24, 2009 | 01:17 AM
BZinn1's Avatar
unless a muffler shop hated you and welded it on it should just be bolted with a flange and donut gasket.........you have to jack up car and put on stands to get in there to work to get it out.
Old Jun 24, 2009 | 01:19 AM
daffy12's Avatar
the nuts for the bolts were welded onto the pipe with mine. so unless it came with its own hardware you will have to buy some new ones. i couldnt find any 9/16 size nuts so i ended up buying new hardware size 3/8. i figured it was close enough...
Old Jun 24, 2009 | 01:31 AM
ok thanks guys... how many nuts did you have to buy 2 or 4?
Old Jun 24, 2009 | 01:47 AM
daffy12's Avatar
Just two. For the ones connecting to the midpipe. The ones connecting to the headers are the spring loaded ones...
Old Jun 24, 2009 | 04:02 AM
Diluvium's Avatar
you let a muffler shop weld it on? they probably thought it did not fit so they cut and weld just in case your header cracked from forcing the spipe to bolt-in. not only that, they want you to pay them agian t take it off
Old Jun 24, 2009 | 05:11 AM
no i havent had it to a muffler shop, i just couldnt see the pipe enough and it looked from my view like it was welded
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
