Tune Up
Old Jul 6, 2009 | 11:51 PM
alejotc's Avatar
Default Tune Up
I did the tune up on my tc (new air filter, spark plugs and pc valve). Do i have to replace the spark plug cables???? My maintenance light still on. I know that i have to change fuel filter. Anybody knows how can i turn off that light?????i don't have my manual.. thank u
Old Jul 7, 2009 | 12:38 AM
uscg_stamant's Avatar
yea bro......this is what you do
Turn the ignition key to OFF position with the odometer reading showing.
Then turn the key to the ON position while holding down the trip meter reset ****.
Hold down the **** for atleast 5 seconds. The odometer will indicate '000000" and your done.
Hope that helps
Old Jul 7, 2009 | 12:42 AM
nodsetse's Avatar
Default Re: Tune Up
Originally Posted by alejotc
...spark plugs...
What was wrong with them...or did you already hit 120k miles?
Old Jul 7, 2009 | 01:06 AM
alejotc's Avatar
Default Thankx a lot
like u said!!!!!!!!! it works!!!!!!!!!!! thank's a lot bro
Old Jul 8, 2009 | 09:26 AM
sciontc_mich's Avatar
Default Re: Tune Up
fuel filter is inside the fuel tank, you'll need to access the fuel pump to get to that. which usually requires you taking the rear seat cushion out to access that..
there are no spark plug wires on the tc (coil packs), which you would've removed them to replace the spark plugs! and then again you saw them, right?
no you don't have to replace the coil packs, they can be checked for primary/secondary winding resistance with an ohm meter. Don't have the specs for the coil packs though.
Old Jul 8, 2009 | 12:34 PM
cburglb34's Avatar
that maintinence light was just to remind ya you had an oil change coming up lol
Old Jul 19, 2009 | 08:50 PM
BOOSTit06's Avatar
tc uses a screen as the fuel filter, no need to replace
Old Jan 13, 2012 | 12:00 PM
jarvasdb1's Avatar
Is this Factual. Just curious.
Old Jan 13, 2012 | 09:13 PM
Spicy_McHaggiz's Avatar
What the thread revival for that?
Old Jan 14, 2012 | 03:10 AM
ESEMRFOZZ13's Avatar
yes, with the fuel shifting back and forth, it's cleaning the screen cover. i tried replacing, and was told no need to.
Old Jan 14, 2012 | 04:55 PM
jarvasdb1's Avatar
Thanks for the reply. Sorry, I didn't realize how old this thread was. LOL
Old Jan 15, 2012 | 04:55 PM
mrexotica's Avatar
A screen for a fuel filter sounds ridiculously primitive. I believe most cars got away from the in the '50s...
Old Jan 15, 2012 | 07:19 PM
ohh and light stays on till reset.
Old Jan 15, 2012 | 07:20 PM
engifineer's Avatar
A filter sock on the pump pickup (no external filter) is very common these days. And unless it is causing problems they a lot of times do not call for a replacement interval, or if so, a very long interval.
alexdrummerr30
Sep 8, 2018 12:18 PM
goldtoaster
Sep 25, 2015 04:58 AM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
Gigs
Sep 15, 2015 03:54 AM
