Tune Up
I did the tune up on my tc (new air filter, spark plugs and pc valve). Do i have to replace the spark plug cables???? My maintenance light still on. I know that i have to change fuel filter. Anybody knows how can i turn off that light?????i don't have my manual.. thank u
yea bro......this is what you do
Turn the ignition key to OFF position with the odometer reading showing.
Then turn the key to the ON position while holding down the trip meter reset ****.
Hold down the **** for atleast 5 seconds. The odometer will indicate '000000" and your done.
Hope that helps
Hope that helps
there are no spark plug wires on the tc (coil packs), which you would've removed them to replace the spark plugs! and then again you saw them, right?
no you don't have to replace the coil packs, they can be checked for primary/secondary winding resistance with an ohm meter. Don't have the specs for the coil packs though.
A filter sock on the pump pickup (no external filter) is very common these days. And unless it is causing problems they a lot of times do not call for a replacement interval, or if so, a very long interval.
vi3tb0i09
Sep 23, 2015 08:32 PM
