Delete!
Old Jul 16, 2009 | 11:00 PM
stillettoDSM's Avatar
Default Delete!
Delete!
Old Jul 16, 2009 | 11:53 PM
BlizZard's Avatar
Default Re: Tein H-Tech Install/Cut TOO MUCH off the Bump Stops!
Originally Posted by stillettoDSM
Another stupid move by me, on two of the four Struts, the Springs aren't sitting perfectly in the Groove at the bottom of the Strut, they're about an inch or so away from it, will that really make a difference?
REDO THEM! NOW!
that is also why your higher on one side vs. the other...
Old Jul 17, 2009 | 12:01 AM
Ok! Then I'm gonna' start over tomorrow morning.
I'm beat after all this.
Old Jul 17, 2009 | 12:05 AM
Also.. when I say "Groove", they ARE fit inside the circle groove in the bottom of the strut, but the end of the Spring, is not in the part where it has a little bump on it.. so that's what I'm considering the "Groove".
Nothing to worry about the Bump Stops though?
Old Jul 17, 2009 | 12:15 AM
BlizZard's Avatar
I wouldn't really worry about the bump stops.
Old Jul 17, 2009 | 12:27 AM
killatc171's Avatar
yea i cut my front bumpstops about half off when i did mine last weekend. and didnt cut the rear at all. but i did the exact same thing you did. did driverside, dropped it, passenger side dropped it and so on. the front you just have to mess with them untill the are in the grooves like they are suppose to be. i would def take thme out and redo them now. mine when put on they didnt line up at the top right but once you spring compress them try and line them up then is the best way to do it. thats what i did at least. but if they are not lined up in the grooves right on top and bottom they wont sit right. and probolly why you are stting higher on one side then the other. i would def take them off and redo them agian.
edwinisdumb15
Regional - Pacific South
Sep 29, 2015 06:06 PM
rmz489
Scion xA Aero & Exterior
Sep 17, 2015 03:24 PM
OCEANMOD7
May 11, 2015 05:01 PM
scion1616
Feb 12, 2005 02:14 PM
