VRD Fogs
So, at some point last fall one of my fogs was hit by a stone and it put a small hole in it, which water then got into and the bulb went out.
I know the easy way to test to see if the fog still works is to put in another bulb, but I don't know what is in there. Any help?
They were the stock bulbs that I received with the fogs, nothing special just yellow bulbs. What are the stock bulbs for the VRD fogs?
Thanks. And yes I searched, I just found information on HID setups.
You definitely don't have real VRD fog lights then... Where did you get them from? That looks like a regular turn signal bulb... and thats obviously not an h3 bulb... Which everyone knows that already.
then at some point the previous person changed the bulbs... i just installed my vrds and those are definitely not the bulbs that came with them brand new. the h3 has a square metal body with a wire attached to that
Yeah, no I know what H3's are ... that's why I said I don't think it is them. I am going to be taking the fogs out and fixing the one of the left ... I will take a look so but I definitely do not remember them being H3's.
Thanks again.
Thanks again.
Well one of my VRD lights broke as well. I ordered it straight from the company with the VRD grills and they had H3 bulbs in it. Maybe they changed the bulb style? I really find that hard to believe though. If you take a picture or two of the housings we may be able to tell you something about them.
OK, I finally had a chance to rip out the fog light and take a peak see, and it is an H3. I am not under the assumption the original selling was giving me the round bulbs for my turn signals for free!
Anyways, I am going to have to repair the fog light, it has a small hole in the front and the ground screw in the bag broke off so I will need to figure something out there.
I want to open up the fog light, do you think it is safe to put it in the oven? I want to loosen the glue.
Thanks guys. Off to pick up some H3s be back soon.
Originally Posted by xdejablu3x
does anyone know if those vinyl shield protectors work on the VRD fog light glass? for foglights in general im always seeing cracked lenses.
Flint_08- yeah you can put them in the oven, just take off the rubber boot and remove the bulb firsst. I don't know if you will be able to get them apart thougn.
