HELP!
Old Jul 19, 2009 | 02:44 AM
NYNCTC's Avatar
Default HELP!
Ok, so I installed my coilovers today and at very low speed (20 and under) the front right side tends to click. It happened as soon as I was done, then went away until I got off the exit I take to go home (about a 40-45 min time lapse). What I am thinking is that either the locking piece is loose causing the spring to move a little or the top three bolts are hitting something. I did loose the pieces that hold the plastic part of the windshield on that side so that is loose as well. When I drove on the highway on my way home from where I did the install (40-45min at 65-75) there was no clicking noise. It happens when I am going straight so I am not rubbing. I know I put everything back the way it was supposed to be, but maybe I didnt tighten something enough. The lugs are tight, checked those first. They are KSports, and they are used so...
So help me ScionLife, please.
Also, I will be taking the car to Firestone to be aligned on Monday, if I can't fix it by then, I'll have them look. Good thing I don't need my car for tomorrow.
Thanks!
Old Jul 19, 2009 | 04:02 AM
Sciontistical_One's Avatar
make sure that the springs are seated correctly... that usually causes the sound you might be hearing... the plastic by the windshield usually doesn't cause much of a ruckus, so I would ignore that... and just focus on the springs and make sure all your bolts are torque to the correct specs...
Old Jul 19, 2009 | 04:08 AM
NYNCTC's Avatar
thanks. Firestone is open on Sundays so i will be there in the morning.
Old Jul 19, 2009 | 07:44 AM
Macavely's Avatar
did the coilovers come with a rubber ring for the top of the mount ? I had something like that on my Celica, I forgot the ring on one side. when I would take off the top mount would hit the chasie and my a sound.
Old Jul 19, 2009 | 08:25 PM
NYNCTC's Avatar
i had a loose spring. fixing it later when it isnt so hot outside.
