Body squeaking?
Old Jul 24, 2009 | 05:59 AM
Coolwaterz's Avatar
Default Body squeaking?
iv noticed when i go on and off my drive way at a angle the car makes a squeak.
all i did was lower it on TRDs. everything is stock.
would front and back strut bars fix the problem? this happens going on speed bumps at a angle too. (if i dont the front bumber will get scratched.
Old Jul 24, 2009 | 07:48 AM
Mos_Def's Avatar
mine does that too. i believe its due to the fact that the roof is made out of glass. i have a front strut bar and i still crack/squeak. not sure on the rear bar. maybe others can chime in on that one.
Old Jul 24, 2009 | 06:09 PM
DanielNC06's Avatar
yeah i put a rear sway bar and front tower strut brace. and now mine creaks in the roof in the same situation your describing. and im on stock springs/struts.
Old Jul 25, 2009 | 04:46 AM
Coolwaterz's Avatar
wow really guys? i starting noticing that a few months ago and hoped it would go away but it seems to be getting worse...
probably need to get some aircraft aluminum and start bracing everything =p
Old Jul 25, 2009 | 10:22 AM
DanielNC06's Avatar
yeah well our cars are fairly rigid compared to some...i can lift the whole rear end if i try to jack up just one of the rear wheels...so...i guess the only consequence is if it gets bad enough to crack the roof but ive never heard of happenig to anyone. Mine started immediately after my installs last year but i havent felt that its gotten worse..
Old Jul 25, 2009 | 03:45 PM
BZinn1's Avatar
yep the car is fairly stiff and it will creak and squeak........mine has now worked its way to the roof as well as I have gotten tighter suspension......it is normal.
Old Jul 26, 2009 | 08:13 AM
Coolwaterz's Avatar
dam why couldnt they use titanium and carbon fiber on the car like what they did to that zonda...XD
Old Jul 26, 2009 | 04:24 PM
senseiturtle's Avatar
At that point, it'd be just as expensive as the zonda.
I've got the "works" on suspension, and it squeaks a whole lot. If you don't carry anything in the rear, taking out those plastic inserts tends to help.
Blunderbuss
Oct 8, 2015 04:56 PM
MeDizzy
Oct 8, 2015 03:31 PM
Andreas24
Sep 15, 2015 02:10 PM
prescottn
Sep 13, 2015 09:04 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
