2008-2010 [ZSP110]
Issue on my 08 xD with AC drainage
Old Aug 7, 2009 | 04:10 PM
haskovec's Avatar
Default Issue on my 08 xD with AC drainage
I am seeing an issue on my 08 xD. When I brought it in for my 15k service I had them take a look at it. Bascially on tight corners I Could hear water sloshing around and it was dripping a bit on the passenger side floorboard. Anyway turns out the drainage for the moisture from the AC unit had gotten plugged with road debris, so they cleared the blockage and problem solved. However now less than 2000 miles later I am having the problem again. Does anyone know where I should look to clear this so I can just fix it on my own? I might need to put a bit of screen or something on there to keep crap out of there. Does anyway else have this problem? Odd that it happens as I only do street driving in Dallas, so it isn't like I Am on gravel or dirt roads.
Old Aug 8, 2009 | 06:27 AM
Sefi's Avatar
If you pull back the front passenger side carpeting there's a black hose that runs from under the dash thru a large hole in the floor board/fire wall. Make sure that's not blocked up.
djcezile
Apr 23, 2015 06:46 PM
nazblue5807
Apr 11, 2015 12:20 AM
zap-o-matic
Apr 2, 2015 07:35 PM
cid_mcdp
Jan 5, 2015 02:45 PM
Besk_one
Oct 18, 2003 08:41 PM
