MobileHID Question??
Old Aug 11, 2009 | 06:09 AM
preapty's Avatar
Default MobileHID Question??
Where is everyone placing the relays for their kits. The website says the relays are not waterproof.
Old Aug 11, 2009 | 05:06 PM
Invertalon's Avatar
I heavily wrapped mine in electrical tape and its behind the drivers side headlight, standing upward... So that the wires exit from the bottom so water can not drip down into the relay. If that happens, you will get flickering, random turn off/on, etc... But you can get a replacement relay for $6 at radio shack if need be!
Old Aug 11, 2009 | 05:09 PM
CarbonXe's Avatar
I'm not even running relays.
Old Aug 11, 2009 | 11:16 PM
preapty's Avatar
Is that safe? I'm still under warranty so, I'm a little cautious.
Old Aug 11, 2009 | 11:17 PM
preapty's Avatar
Does the relay heat up? I was thinking of Fab-ing something for it.
Do you have a picture?
Old Sep 3, 2009 | 05:24 PM
XVR4667's Avatar
It is cheaper and easier to buy a harness, plus all the time you save.
I was going to do the same, get my parts and wire it up, but after about an hour I finally stumbled across these guys on ebay for less than $11 shipped. Plus you get a 1 yr warranty. By the time you get all the parts and connectors you'd spend just as much if not more. I just got mine installed last night. It was a tight fit but the wire lengths just made it. It turned out to be a 60 amp relay, so if you could add more on it.
Old Sep 3, 2009 | 05:26 PM
CarbonXe's Avatar
Been running the same ballasts for 3+ years without a relay, haven't had a single problem.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
