AMP install question for the tC
Old Jan 29, 2005 | 02:15 PM
PRacing_com's Avatar
Default AMP install question for the tC
How do you hook up your pre-amp outputs to the stock HU?
It has no inputs obviously, would I need a line out convertor, if so where/how to install it?
I know a lot about car stereo, but my other car has a BOSE sub in it, I wired my amp directly to that... any help please reply.
Old Jan 29, 2005 | 02:22 PM
SCI_TC_GUY's Avatar
You can get a part from any stereo shop or wal mart even that is a line level converter....either that or get an amp with high level inputs...
for the converter, You'll take the speaker wires running to one of your speakers and just splice into them...then on the other side of the converter box is your pre-amp outs..RCA cables....whatever you wanna call them....if I were you....I'd just get a good amp with some high level inputs like rockford or sumpthin.....
Old Jan 29, 2005 | 02:33 PM
Found the post, hehe. Thanks... I do have high level inputs, where would I wire them to? Thanks... ASAP anyone, I need to install this now.
Old Jan 29, 2005 | 02:37 PM
SCI_TC_GUY's Avatar
it's the same as the converter.....splice it into the stock speaker wires....
Old Jan 29, 2005 | 02:39 PM
So... I would splice to the right and left rear speaker wires?
Also, what about the remote wire, what do you recomment? Anything in the trunk?
Old Jan 29, 2005 | 02:53 PM
SCI_TC_GUY's Avatar
hmmm....i don't know.....if it were me I'd probably just go to the fusebox for something that comes on with ignition.....since you're gonna have to run a power wire to the battery anyway....you might as well get something good in the fuse box and run them together at the same time.....get on yahoo messenger....i'm jdm_4g63 on there...
Old Jan 30, 2005 | 02:56 AM
tbone587's Avatar
When I was using the high level input for my amp at the time of using my stock head unit, I Just just tapped into the speaker wires in the stock wiring harness. And I believe I used the power ant wire for the remote turnon. The downside to this is, the amp is always on and doesnt turn off even if the head unit is off
Old Jan 31, 2005 | 12:22 AM
ChefRaekwon's Avatar
Buy a Toyota reverse harness while ur at it. Instead of cutting ir splicing any wires on the harness built into the car. Also you can use the remote lead on the reverse harness to power up the amp.
Old Jan 31, 2005 | 12:27 AM
Theanks for the info. I used high level inputs, wired them to the eft rear speaker, and still want a good place to get the remote turn on... know any good places, more specific. I am not familiar with the scion or toyota harness.... do you mean behind the H.U.?
Thanks.
Pathik Patel
Www.mazda6stuff.com/scion.htm
Old Jan 31, 2005 | 05:36 PM
Any help, please, would be greatly appreciated!
Old Jan 31, 2005 | 05:41 PM
SCI_TC_GUY's Avatar
all you need is to connect to something that's only got power with the key turned on.....like wipers, cig. lighter....moonroof, windows......any of those.......hit it up in the fuse box.....just be sure to get on the correct side of the fuse....otherwise you could have a smoking problem....
Old Jan 31, 2005 | 11:59 PM
Yeah, we did that, tried about 4 different fuses.
I dont know, I think I will check back again, all the wiring, the wiring that is.
Also, did you do high level inputs, and how? which wires, thanks.
Old Feb 1, 2005 | 05:51 PM
SuperCrunchyAction's Avatar
Listen, it's not that difficult. Here's a wiring diagram for the xb. Tap into the rear speaker wires on the harness and hook your amp turn on lead to the Radio Switch wire on the harness.
Old Feb 1, 2005 | 11:46 PM
Thanks everyone for the help. I got it to work, had it right the whole time. Turned out to be a badd connectiuon in one of the wires. Also, I was asking about the tC.
Thank you all for your help, I appreciate it. I ended up using heigh level inouts, and tapped the left rear speaker in the "wall"
PLease visit www.mazda7stuff.com/scion.htm for unique, custom, and hard to find parts, thank you.
wiltonhall
Jun 23, 2025 10:09 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
cwong1001
Dec 3, 2014 03:30 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
