2004-2006.5 [NCP61]
Trouble starting 2005 scion xa
Old Aug 20, 2009 | 02:32 PM
dtpmike's Avatar
Default Trouble starting 2005 scion xa
My wife has been complaining that her 2005 scion xa sometimes will not start.
She will park at a store for instance, shop and then come back to a car that will not start. She turns the ignition and no response from the starter at all.
Usually after several tries or waiting a while the car will finally start.
There was an aftermarket alarm installed when we bought the car... I removed the computer from it, but I left the starter disable circuit on there for now since I did not have time to cut/redo the wiring.
ALSO she said she noticed that her clock time had been reset (She noticed it was 1pm when it was about 4pm).
ANY IDEAS of what it could be?
I already plan on removing the starter disable curcuit that remains from the aftermarket alarm (not connected to power or the alarm brains currently). I also thought maybe the battery terminals were loose (could explain the clock being reset).
Old Aug 22, 2009 | 07:39 AM
mb2008's Avatar
Since the clock resets when you disconnect the battery that might be the cause, no power to the starter. Do you know if that alarm disconnects the battery somehow? Did she notice if the dome lights came on when she opened the door the times it didn't start?
Old Aug 25, 2009 | 01:44 AM
dtpmike's Avatar
the positive wire pulled right out of the crimped end with my hand.... obviously it was not tight enough... I crimped it with some pliers now it is secure. I think this will fix the problem.
AbsoluteRedtC
Dec 31, 2014 06:18 PM
lunchbx05
Dec 29, 2014 07:53 PM
minter66
Dec 15, 2014 01:45 PM
BV19869
Dec 11, 2014 06:05 PM
tC_Normo
Oct 22, 2003 07:20 PM
