Review: OS Giken on Dezod S1 @ 12 PSI
Well, as many of you know, we have had a local customer's car for about a month while we performed a laundry list of mods to the car as far as additions. One of the mods this customer elected as an OS Giken locking LSD like this:
The car also had a Energy Motor Mounts installed at the same time. The car was a tremendous difference after both mods where added to here. She was much more stable overall. No torque steer, very predictable and responsive as a whole.
The car was able to be slammed into corners at 12 PSI with 100% throttle and she was pulling into the turn VERY hard. The LSD was absolutely the best mod for this car he could have done. She has the ability to dart in and out of corners with ease. Steering responsiveness is sooo there especially with his 245/40 Dunlop Direzzas on Dan G RPF1s, KW V2 coilovers, Energy mounts and this LSD. The car's traction is now a function of tire grip and suspension tuning and nothing else.
Hands down, the BEST turbo tC I have driven with a Diff. I have driven quite a few Quaife cars, and none compare to the feel of this car.
On a side note, Don is even harder to please than me, and even he was "wowed" about this diff as a whole.
Figured I would share.
This diff is in stock and for sale here at Dezod....
http://www.dezod.com/pd-os-giken-lim...tial-2azfe.cfm
This is a friction disc based full locking diff. These tend to create more heat in the trans case than a torque biasing diff like Quaife/TRD. As a result of the added heat, a heavier duty fluid will need to be run, but the selection of the proper diff fluid is essential because the diff is in the same housing as the trans, syncros and gears. This not like a RWD Supra or IS300 where they are separated.
The proper fluid to run, after some trial and error, is very specific. A race app might want to use a shock-proof heavy or mixture where the fluid is something like 75w140. These diffs require a thick fluid because of the heat, however your car only calls for 75w90 GL4/GL5.
GL5 has a friction modifier, which is near essential for this diff. You do not want the friction plates to bind at low speeds, they are supposed to slide across one another in this scenario, but at the onset of TQ, fully lock in a 1.1 ratio.
So other than requirements of fluid, service interval will be contingent upon how you drive the car. A normal driven street car, 3K miles for first fluid flush to ensure that all contaminants are flushed from the system. Then an interval of 30K miles will do for flush and refill of fluid.
Lastly, we tried Redline MT90 with no success on this diff. We are now running Motul Gear 300 and she runs perfect.
They do wear out eventually, and if you are making say 400+whp and beating the ever loving snot out of it every second, they will go faster. OS claims to have some cars in Japan that have over 70K miles on them without being rebuilt. So you be the judge!
I've had my eye on the OS, but finding a shop that i think would touch it is hard. Might have to talk to you about it paul when that time comes.......wow, seems so far away, ahh!
redline didint work huh? ive found redline to be the best fluid in my tranny so far
only fluid that gives me perfect shiffting during my racing.. id hate to have to change it becasue of diff
Can the trd lsd be used with mt90?
PTuning uses Mt90 on their TA tC with the TRD LSD...
The good thing is that it is easier to find a fluid with GL-5 then it is to find a fluid with GL-4 only. Most all gear fluilds commerically sold meet the GL-5 rating. The E350 transmission calls for a 75w90 GL4 or GL5 rated fluid. So it makes no difference which you run for the stock setup. This diff requires a GL5 fluid. So just make sure you run GL5. If you are looking for a synthetic transmission fluid that meets all these requirements then check out Motul Gear 300. However anything will work. Motul is just a higher tier fluid which stands up to much more abuse.
http://www.dezod.com/pd-motul-1l-bot...uid-105-qt.cfm
I have driven both Quaife/TRD and OS giken diff cars. The OS giken is a little louder but it has much more in terms of mechanical moving parts. It is a true locking diff. Much like the old Detroit lockers of old days but these are the best type performing differentials available, period.
These lock no matter what because they are preloaded by springs and clutch plates. There is no choice. As soon as the power is applied the wheels are locked. The quaife/trd can become unsettled in a launch or heavy turn if the wheel lifts from three wheeling or wheel hop.
Very Interested in this LSD and plan on start saving for it after I get my turbo kit. For an extra $300 over other LSD isn't that bad. I've been hearing nothing but great things about OS and is worth every penny.
my06tc
Jun 25, 2015 12:18 AM
Kumitsu
205
May 8, 2007 05:20 AM
Joe_Dezod
1007
Jan 2, 2007 05:24 PM
Joe_Dezod
29
Dec 25, 2005 10:13 PM
