TOGA HP Bearing
Old Aug 25, 2009 | 03:19 PM
Giupo's Avatar
Default TOGA HP Bearing
I must to change the Oem bearings with TOGA HP bearings Mains e rods but I have very difficult for the sizes because the Oem bearing are a marked 1,2,3 etc but the Toga Hp bearings does't have this marked but have only STD, .010, .020 etc size.
How I make to choose the correct measures?
Can you help me please?
Thanks
Giupo
Old Aug 26, 2009 | 05:48 AM
itsme's Avatar
i have em and you can put them in any order but be sure to order std. unless you had to go get your crank turned and if so you would have to ask the machine shop that did it for you and i would suggest you take it to a machine shop to have the main bearings put in because our block doesnt have the notches for the toga bearings
Old Aug 26, 2009 | 07:30 AM
Giupo's Avatar
thank you for answer but I don't understand well because the OEM bearing have a different clearence and the TOGA bearings doesn't have.
The .010, .020 and over sizes what they refer?
OEM Main bearings:
OEM Rod bearings:
Old Aug 26, 2009 | 08:46 PM
Giupo's Avatar
The Toga Hp bearings aren't direct fit in 1nzfe??
Old Aug 27, 2009 | 07:00 PM
itsme's Avatar
nope....i thought they were but they're not =( the rod bearings go in no problem but the main bearings are another story...
Old Aug 28, 2009 | 12:06 PM
Giupo's Avatar
how you have made to instal them???
Old Aug 28, 2009 | 10:03 PM
itsme's Avatar
i took it to a machine shop and had them put it in
Old Sep 1, 2009 | 06:54 PM
Giupo's Avatar
Have you some photo?
Thanks
Old Sep 1, 2009 | 07:26 PM
vettereddie's Avatar
Huh, I will try this today. I have the Toga bearings but haven't installed them yet. I am in the middle of notching the cylinder wall for the connecting rods themselves. My block is an 04 I think and it definately has a notch for the main bearings. I'll try and grab pictures tonight.
Old Sep 2, 2009 | 06:57 AM
itsme's Avatar
naw sry man no photos i had photos up until i got a new computer after that the old computer went bye bye.....i had/have a 05 block and it didnt have the notches for the main bearings i have yet to crack open my other two blocks to see....
Old Sep 2, 2009 | 01:18 PM
Confirmed, my block has notches on both the cap and block of the main bearings. The odd thing is that the block side notch is offset, the cap side is centered. itsme, how much of the work was done at the machine shop? Are you confusing notching the block to get the connecting rods themselves to fit with notching bearing journals?
Unfortunately I left the Toga bearings at the house so couldn't test fit them at the shop, but here's the raw pics of the journal face. (1st pic, block journal 2nd from bottom has the bearing removed. 2nd pic, just the cap)
Attached Thumbnails TOGA HP Bearing-img_0130.jpg   TOGA HP Bearing-img_0131.jpg
Old Sep 3, 2009 | 04:46 AM
itsme's Avatar
huh im kinda lost on what i just read as far as asking me if im confusing notching the block to get the connecting rods themselves to fit with notching the bearings.......i have stock connecting rods.....i just rebuilt the motor because i blew the head gasket and was like hrrmmm why not upgrade the bearings....as for work being done to the block i just went to them and pretty much said make it fit lol
Old Sep 3, 2009 | 04:03 PM
Ok, didn't know you were still on stock rods. I figured if you had new bearings, you must have swapped rods too. The aftermarket Crower rods will hit the cylinder wall on the exhaust side so a groove needs to be cut in the bottom of the cylinder to get them to clear, that's what I mean by notching the block.
If you're on stock rods and they still said a groove needed to be cut for the bearing tab, that kind of sucks. Guess I lucked out with the 04.
Guipo, what year is your engine? I can confirm if Toga will fit or not on the 04 and 06. Order standard, and to check the bearing clearance, use a product called plastigauge, the smallest one they make. It's a little piece of wax thread that squishes between the bearing and crank that is then measured to give you bearing clearance.
Old Sep 3, 2009 | 07:36 PM
Giupo's Avatar
my engine is year '05 and don't have a notches for main bearing
Old Sep 3, 2009 | 08:06 PM
Buy a spare 04 block. The sensor connectors may change but you can still screw them into the block for any year 04-06. Are you resident to Italy or just stationed there and bringing the car stateside? I use car-part.com to track down used stuff here but they only cover the US, Mexico and Canada. Maybe you could find something like that there. I picked up the block I'm building for $250.
Old Sep 4, 2009 | 07:29 AM
Giupo's Avatar
Ok, I have bought a new block in Italy... I must meke a notches for the main bearings :-(
Old Sep 23, 2009 | 07:53 AM
sparcshinobi's Avatar
This might sound silly but are you guys upgrading your bearings for a turbo setup? Or, will this help improve performance on a non aspirated engine? School me!
Old Sep 23, 2009 | 07:56 AM
I have an 06 Xb with a Fujita cold air intake, DC headers, catback exhaust, and I only pump premium.
Old Oct 3, 2009 | 11:51 PM
grip95's Avatar
That would be upgrade for upcoming engine mods
yupinmytC
22
Jul 27, 2024 07:08 PM
rain7905643
Jun 13, 2018 05:29 AM
corbinortiz
Oct 2, 2015 02:45 PM
BlingSlade
Sep 5, 2015 08:52 AM
alexbarspin
Sep 3, 2015 02:04 AM
