How will my xA handle with 17"s on it?
Old Aug 27, 2009 | 08:38 PM
dtpmike's Avatar
Default How will my xA handle with 17"s on it?
How will it affect handling and/or acceleration with 17"s?
Will my speedometer be off?
http://www.discounttire.com/dtcs/fin...8415&rc=FLTINT
I might buy a set of these used from someone locally. What do you think?
Not sure what size tire he has on them either... wheels and tires only have 800 miles on them.
Old Aug 27, 2009 | 08:42 PM
draxcaliber's Avatar
depends, if the new combined wheel and tire package is heavier than what you have now, your acceleration is going to be slower due to the increase in rotational mass. braking will also be effected, but chances are the new tires could have better traction than the OEM tires, so braking distance could be a toss up, as well as handling. depends on which is greater, the increase in unsprung weight, or the increase in tire grip cornering force.
your speedometer will be off if the overal wheel and tire diameter is significantly different from the OEM wheel and tire diameter. this will also throw off your odometer, and tripometer.
Old Aug 27, 2009 | 08:44 PM
dtpmike's Avatar
Oh yeah... I have the stock 2005 steelies/ Hub caps right now.
Old Aug 27, 2009 | 08:47 PM
discount tire has a tire size calculator, where you put in the OEM tire size, and the new tire size, and it will tell you the difference in diameter and how it will effect your indicated speed versus actual speed.
oh, and also, your ride will be rougher because less sidewall means less cushion.
Old Aug 27, 2009 | 08:48 PM
ack154's Avatar
A lot will depend on the tire size... kind of like drax is mentioning. Ride quality, speedo difference, etc.
Old Aug 27, 2009 | 10:08 PM
dtpmike's Avatar
do you think my mpg will change if I the tires are 205 45 17?
Old Aug 27, 2009 | 10:12 PM
ack154's Avatar
Well if the wheels/tires turn out to be heavier than your OEM setup, then yes, you MPG could decrease.
Old Aug 27, 2009 | 10:23 PM
also factor in additional roll resistance, and your mpg could go down too.
Old Aug 27, 2009 | 10:55 PM
nodsetse's Avatar
If the overall diameter is larger than stock, your mileage might improve a bit due to gearing, which would be offset by the increased weight and resistance, so mileage would probably be unchanged overall.
If the overall diameter is the same you'll lose a little, like the guys above already said.
Old Aug 27, 2009 | 11:31 PM
killerdungbeetle's Avatar
here's a calculator for ya: http://www.miata.net/garage/tirecalc.html
I've got 18s on mine, and it's pretty darn bumpy and a bit slower off the get go.
My overall tire size is nearly the same as stock though, because of the low-profile tires on there now.
SoccerBoy_AP
Oct 1, 2015 06:28 AM
Frankie_Xenon
Sep 2, 2015 12:22 AM
Threequalseven
Aug 26, 2015 04:24 PM
chabruce
Aug 14, 2015 03:25 PM
Subaru86
Jul 31, 2015 04:00 AM
