best/most recommended spark plugs for f/i
Old Aug 28, 2009 | 03:40 PM
troy2003's Avatar
Default best/most recommended spark plugs for f/i
just curious, going f/i in a month, as far as electrical i have the sun auto hyper ground, and voltage stabilizer, going with nology hotwires...any recommendations as to what plugs would be best on my f/i setup.
Old Aug 28, 2009 | 04:44 PM
zendog31's Avatar
I would most likely use NGK or Denso. I have seen a lot of people use iridum plugs but most don't care too much for the price of them.
Old Aug 28, 2009 | 04:47 PM
ElevationTC's Avatar
i run iridium plugs, and i run coil over plug setup with no issues! why would u change it?
i run 3 step colder myself!
Old Aug 28, 2009 | 04:51 PM
CarbonXe's Avatar
NGK Iridiums.
/thread
Old Aug 28, 2009 | 04:59 PM
KCTTC's Avatar
NGK BKR7EIX
-Jeremy
Old Aug 28, 2009 | 05:20 PM
Originally Posted by KCTTC
NGK BKR7EIX
-Jeremy
thats 4 steps colder i think thats a little on the higher boost levels wouldint u say?
Old Aug 28, 2009 | 05:22 PM
Crush Automotive Customs's Avatar
nope i think those are the one step colder
the two step's are bkr8eix
stock is bkr6ix-11 (i think thats right)
Old Aug 28, 2009 | 05:34 PM
wow i FAIL
LMao ur right!
http://www.dezod.com/cat-spark-plugs.cfm
sorry
Old Aug 28, 2009 | 05:38 PM
troy2003's Avatar
why would i change??, you mean from stock, if thats the question, beacause the better conductivity of plug wires, and plugs with durable spark, the more optimal the detonation, thus improving throttle response. Those upgrades tend to see better benefits in f/i setups as opposed to n/a, i made the upgrade in my old n/a setp, an sr20de, and noticed little to nothing. Furthermore going f/i, with having the ground and voltage stabilizer, with step colder plugs and nology wires, i want to achieve a smoother idle, and quicker smoother starts. Am i going the right direction with this?? ive never owned f/i, but in all the reading and research i have done over the years, many articles praise ignition and electrical upgrades on f/i setups.
i look to pull out 300 +/- to the wheels, would 1 or 2 step be recommended?
Old Aug 28, 2009 | 05:41 PM
Ur only creating more resitance by adding wirings, you have the most direct possible conection now!
You dont opitmal detonation, you want none!
get colder plugs ditch the other junk
Old Aug 28, 2009 | 05:43 PM
troy2003's Avatar
so stock wires, step the plugs??.
Old Aug 28, 2009 | 05:46 PM
two step colder. leave everything else alone you mentioned!
Do alot of searching on here and you will learn alot man!
Old Aug 28, 2009 | 05:52 PM
troy2003's Avatar
thanks man...will do, i plan to leave the sun auto hyper ground, unless of coarse it causes me major issues with numbers during the tune (which i doubt), but again, thanks.
Old Aug 28, 2009 | 06:40 PM
gompka's Avatar
I think you are getting confused. You don't need to get sparkplug wires for the tc because stock you have the coils right on the sparkplug. Its not like the older type of ignition that required a wire from the the coil to the sparkplug.
Old Aug 28, 2009 | 06:45 PM
troy2003's Avatar
yea, i realized that, ill learn the basics and get more in depth with f/i once its all installed and tuned...my tuner back in pa does a good job of teaching you about your car as he tunes....so that will be a huge day of good knowledge for me. my sr20 had a seperate coil pack...i know the difference now, thanks man.
Old Aug 28, 2009 | 06:50 PM
wow i FAIL
LMao ur right!
sorry
I only know that cause i get that question quit a bit...lol
Old Aug 28, 2009 | 07:18 PM
m6ar2cel6oTC's Avatar
i use 2 step colder v power plugs do the job well!!! and cheap!!
Old Aug 28, 2009 | 08:36 PM
Ace83's Avatar
Ronin Scion
iridium step 2 colder and stock coil packs.. ive heard some bad reviews of upgrading to hotwires when it comes performance on this car.. Our stock coils are the best available system.. you would get some gains on the sr20 since their stock is old technology and hotwires would be an upgrade for that car
kleecker
Jul 11, 2015 09:39 PM
my06tc
Jun 25, 2015 12:18 AM
tCSpdRacer
May 2, 2015 03:33 PM
daniinpitt
Apr 4, 2015 08:07 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
