Parking brake light is stuck on
Old Aug 31, 2009 | 11:59 PM
wkujesus2's Avatar
Default Parking brake light is stuck on
My parking brake light is always on. It use to stay on until I gave it some gas then it would go off. Now it just stays on all the time. Does anyone have any suggestions?
Old Sep 1, 2009 | 12:04 AM
ack154's Avatar
Your brake pads are probably low - which is causing your fluid reservoir to be low - which causes your brake light to come on.
So check your pads.
Old Sep 1, 2009 | 12:21 AM
Steventc07's Avatar
+1, check your pads/brake fluid
Old Sep 1, 2009 | 01:01 AM
SquallLHeart's Avatar
*nods*.. check your pads.
Old Sep 1, 2009 | 01:02 AM
engifineer's Avatar
Dont add more fluid unless you find a leak and fix it. If there is no leak and it is low, you need to replace the pads. The fluid level will then be back at the correct place.
And for reference, that is not a parking brake light. It comes on when the park brake is on, but it also tells you when you are losing brake fluid or if there is another brake pressure related issue in the system.
Old Sep 1, 2009 | 02:16 AM
Steventc07's Avatar
^LOLOLOLOL @ your sig
Old Sep 1, 2009 | 04:08 AM
engifineer's Avatar
Yeah.. that guy was way too out there not to quote !
Old Feb 17, 2010 | 02:30 AM
WillyB's Avatar
Mine has been coming on too, but only when i accelerate hard.
Do you guys think I should do the same?(check the fluid and pads)
Old Feb 17, 2010 | 04:16 AM
TcPrincess's Avatar
^ you need someone to tell you to go look at your brake fluid level?
Old Feb 17, 2010 | 12:04 PM
ack154's Avatar
Yes, that is exactly what it is. The acceleration (and inertia) cause the fluid to swish around so it reads low at those times and kicks the light on.
Old Feb 19, 2010 | 11:57 PM
05-sw-tc's Avatar
there all correct, check your brakes; Front and rear. adding brake fluid will not fix the problem
Old Feb 20, 2010 | 08:44 PM
WillyB's Avatar
Yep. Checked the pads, and I have a little less than a 1/4 in of pad left. So I topped off the fluid, and hasn't come on since. It's still probably a good idea to change my pads, my local parts store only had the cheap ones, so gunna place an order in a week or so for some good pads.
Thanks
Old Feb 20, 2010 | 11:44 PM
ack154's Avatar
Thanks
Ya, topping off with fluid will turn the light off for now - but just know that when you put new pads on and have to push out the calipers, you will probably overflow that reservoir. So you may want to suck out a little bit of fluid with a turkey baster or something before moving the calipers.
Old Feb 22, 2010 | 05:31 PM
jsmillie07's Avatar
Definitely take some of the fluid out before pushing the piston back in. You don't want brake fluid to touch your paint it could eat through it.
Old Feb 26, 2010 | 07:11 PM
engifineer's Avatar
*** Edit, that wasnt aimed at you js. The post it was aimed at has been deleted now so it just looks that way****
^^ didnt you get post removed trying to sell something pretty much right when you joined? As an FYI, posing a ton of few word posts a day just to reach 50 can also get you banned. Mods are not too friendly about that. I say this because bascially every post you have made since then is just agreeing with what others have already said and almost all of them just have a few words in them.
xBSciontist
Jun 18, 2019 03:06 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
bruceb25
Nov 23, 2014 04:52 AM
randode
44
Jun 29, 2004 04:19 PM
crystaljukebox_com
Dec 16, 2003 08:34 PM
