Knukonceptz in line fuse holder question.
Old Feb 1, 2005 | 01:20 PM
tbone587's Avatar
Default Knukonceptz in line fuse holder question.
I bought this http://www.knukonceptz.com/productDe...m?prodID=FH-24 in line fuse holder from knukonceptz. I dont really know how to inside the wire into it. I have the correct size alan key to loosen the screw, but there wasnt enough room to stick my 4 awg wire in there. So I took out this little barrel piece that was removable and it fit. I tighted the alan key as much as I could and then screwed back on this piece to the end. On the ends of the fuse holder, there are these red rubber things, but there is no way in hell the 4 awg wire would fit thru that. So I just took them out.. Maybe someone has used knukonceptz fuse holder before.
Old Feb 1, 2005 | 05:46 PM
SuperCrunchyAction's Avatar
I'm sure the red rubber seals will fit over 4 gauge wire You need to stretch them on there before you strip the wire. You did strip the ends of the wire, right?
Old Feb 1, 2005 | 06:49 PM
tbone587's Avatar
trust me, there is no way they are gonna fit.. I just talked to knukonceptz, and they said the rubber piece was only if u were going to use 8awg wire.
Old Feb 1, 2005 | 06:54 PM
grnxb's Avatar
Not that I can help, but I bought this http://www.knukonceptz.com/productDe...prodID=BC-1428 and still can't figure out how to use it.
rshissler
Mar 24, 2015 10:46 PM
LVXB
20
Sep 24, 2007 07:07 AM
fearturtle44
15
Feb 13, 2004 01:15 AM
fliggah
Dec 25, 2003 01:03 PM
Besk_one
Nov 17, 2003 09:28 PM
