Problem code P2118
Old Sep 21, 2009 | 12:33 AM
rhythmnsmoke's Avatar
Music City Scions
Default Problem code P2118
I am throwing a P2118 code. Just wanted to confirm that my throttle body as gone kaput on me. I looked the good up in a generic code book and it comes back as:
Throttle Actuator Control motor current range/performance
Does that mean the TB is jacked or is there something else associated with the Throttle I should be looking at. I have a spare TB and just wanted to be sure that's it before wasting time changing it.
Old Sep 21, 2009 | 01:20 AM
TunerKid's Avatar
try resetting it and see if it comes back on. if youve opened the butterfly without the pedal(i.e. a screwdriver)it will sometimes throw that code. i had cleaned my TB and that code up, i just reset it. havent seen it since.
Old Sep 21, 2009 | 01:22 AM
elcapetan's Avatar
How do you reset it.. Are you talking about resetting the ecu as in unplugging the pos. terminal from the battery?
Old Sep 21, 2009 | 01:37 AM
Music City Scions
I have tried clearing the code with the tool only to have it come back. What are the reset procedures?
Old Sep 21, 2009 | 02:09 AM
m6ar2cel6oTC's Avatar
if it keeps coming back its your TB. most likely the sensor cause if it was the actual butterfly or the gears in the TB it would say it is Throttle actuator stuck open or closed. unplug the sensor and see what the reading is. i think it should be like .4 and up. i forgot what it should be at check the shop manual if you have one if not i will look it up when i get home for you.
Old Sep 21, 2009 | 02:40 AM
Music City Scions
Check with a volt meter you mean? I think we have one laying around the garage.
Old Sep 21, 2009 | 03:52 AM
yup. with a volt or multimeter whatever you have in handy.
Old Sep 21, 2009 | 03:55 AM
i checked the shop manual and it says this what P2118 means (Open in ETCS power source (+BM) circuit (1 trip detection logic))
and this is the trouble area (Open in ETCS power source circuit, ETCS fuse, ECM)
Old Sep 21, 2009 | 03:59 AM
Music City Scions
If you find out what the proper volt reading is, let me know.
Old Sep 21, 2009 | 04:02 AM
Music City Scions
Can you translate that into English now? So it might just be a fuse is that what it's saying? Where the hell is this fuse cause I swear I checked all the fuses in the Bay. I didn't check in the inside of the car though.
Old Sep 21, 2009 | 04:09 AM
the etcs fuse is in the engine bay its a 10A fuse. ok found the reading it should be at 0.3 to 100 Ω at 20°C (68°F). you check the 1st 2 pins from the coolant lines side. if that makes any sense.
Music City Scions
Found on ClubSciontC
Originally Posted by Rated tC
OK, I decided to look further into it regarding P2118 fault code, throttle actuator control motor. According to my resource, the throttle motor built into the throttle body is managed by the ECU which uses driver input values via the rheostat/potentiometer in the accel pedal to determine throttle opening angle percentage. However, the main throttle control circuit requires battery voltage as an input going into the ECU to be able to control the throttle actuator on the output circuit side of the ECU. The 12V input to the ECU has a 10A ETCS fuse in line. This fuse is located in the fuse box on left side of engine bay behind the left headlamp housing. I'd check out that ETCS fuse first. It may have high resistence or it may have just blown. I'd just replace it completely with the available spare 10A fuse.
Your engine right now is probably running in a Fail-Safe mode under conditions of a malfunctioned throttle control system. I wouldn't recommend driving while the engine is running under this mode. Replace fuse as neccessary, clear the code, and see if that code comes back. If it does, then your ECU or related circuits may need further diagnosis. But, it's pretty simple checking that fuse first to save you money on additional diagnostic fees.
Could have SWORN I checked all those fuses. Guess I'll have to look again.
Old Sep 21, 2009 | 04:11 AM
hope that helps
Music City Scions
So, if fuse is still good, then TB bad. Will check tomorrow. Hopefully there will be enough of a break in this freaking TN Monsoon we got going on right now.
Old Sep 21, 2009 | 07:56 PM
Music City Scions
Took another look see and found the ETCS fuse. Turns out it was blown afterall. I had to actually look at the one side as one side looked good, but the other side was broken. Fuses are so tiny so my first time looking at it, I over looked it.
Old Sep 21, 2009 | 08:32 PM
lmao DUH! glad you fixed the problem!
Old Sep 21, 2009 | 08:35 PM
CarbonXe's Avatar
Fail. Use a DMM next time instead of just looking at the fuse.
Old Sep 21, 2009 | 09:24 PM
Music City Scions
LOL...yeah now I have to get back to my ORIGINAL problem. Think my throw out bearing has gone bad.
SILENCE Mortal!!!
Old Sep 21, 2009 | 09:54 PM
SILENCE Mortal!!!
oh oh. cant help you there. what clutch do you have?
Old Sep 21, 2009 | 10:40 PM
Music City Scions
CC Stage 4
