Fuse or relay for the headlights?
Old Oct 2, 2009 | 03:19 PM
Sunny's Avatar
Default Fuse or relay for the headlights?
This morning on my way to work, my headlights cut off.
My high beams work, but headlights dont.
Maybe I am misreading the fuse/relay guide, or maybe I am just blinded by my fury, but I can't find if its a fuse or relay I need to be looking for or if its its a burnt wire somewhere.
Please help!
Old Oct 2, 2009 | 06:58 PM
AcidDrop's Avatar
if you have HIDs then check your bulbs and ballast if not then check whatever kind of bulb you have in there. if it's neither then check your fuse box and look under the cover to see which fuse it is for your low beams.
Old Oct 4, 2009 | 03:36 AM
SentraSE-R's Avatar
I thought relays were just low voltage switches. Failure of both low beams would indicate your problem is a fuse, rather than bulbs or a relay. If you've modified your lights, look there after checking your fuses.
Old Oct 4, 2009 | 05:50 AM
daneisthegreatest's Avatar
you have 2 10 amp mini fuses under the hood in the fuse box by your battery. check those, but it is pretty uncommon for both headlight fuses to blow at once.
if you have HID's then look at those fuses i talked about in the above sentence and if you have an HID wiring harness, check the relay to the harness and the fuse in the harness itself.
also check the bulbs to see if maybe just maybe just your low beams went out for some odd reason.
carid
Scion tC 2G Aero & Exterior
Sep 1, 2015 09:08 PM
SoCal_CJ
Scion tC 1G ICE & Interior
Jul 14, 2015 09:14 PM
nightwitch
Jul 14, 2015 01:58 AM
Jonny5ive
Jun 12, 2015 08:06 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
