Installing NOS SNIPER WET KIT (10 NITROUS QUESTIONS)
Car: 2006 SCION TC
1. do your cars have a test port on the fuel rail? (is it easy to access so i can run a line from there to the fuel solenoid?)
2. is your stock intake plastic (i'll just drill a hole and tap the 1 nitrous jet & fuel jet in there)
3. wiring things from the fuse box then trying to get them in the car is it easy?
4. if we are spraying a 50wet shot off the start what jets would be recommended?
5. how much fuel pressure does your car get at the fuel rail?
6. is it safe on a completely stock scion tc to run a 50wet shot? car has 80k+ miles (mostly all highway)
7. on my car i have a wideband but i noticed on your cars ur cat is inside the header. if u were to install a wideband where would you put the sensor??
8. what type of custom fabrications will i have to go through to install the kit?
9. has anyone installed a nos sniper kit and or whoever has nitrous installed on there car can i please get some pictures?
10. any recommendations before i buy this kit and install it?
THANK YOU FOR WHOEVER CAN HELP!!!
50 wet is fine, u can even go higher... you can look up the jet calculator for each size shot online... i believe there is one on dynotunenitrous.com
i have mine tapped into my cold air intake, i dont know how it will work on the stock box...
our fuel pressure is 45psi i believe.. and wiring shouldnt be too difficult... i would get the fuel line adapter from zex so u dont have to drill into the fuel supply
Car: 2006 SCION TC
no i just drilled and tapped the fuel rail...remove rail to do this its easy
its rubber, drill a hole and use the supplied nut that has threads on the outside and inside the hext part goes in the intake and through the hole...and then srew the nozzle into that
fuse box? hmm i wired all of mine directly to 12v which is the battery and then i had a swtich in the car that activated the actual relay and my toggle switch
google "nos jet chart"
more than enough im sure its 45-50
6. is it safe on a completely stock scion tc to run a 50wet shot? car has 80k+ miles (mostly all highway)i sprayed a 75 shot every weekend a bottle every week
7. on my car i have a wideband but i noticed on your cars ur cat is inside the header. if u were to install a wideband where would you put the sensor?? if u can fit one on the other side of the pipe where the first o2 is
8. what type of custom fabrications will i have to go through to install the kit? tap fuel rail and drill for bottle brackets
whish i had pics but i had sniper kit
read the instructions thuroughly...make sure you use the right jets
k answered
hampton1100
May 28, 2015 07:32 AM
Beesh
Jan 9, 2015 06:30 PM
spawnconnery
Dec 18, 2014 08:38 PM
Basebllstar
Dec 17, 2014 07:30 PM
