little help with afr plz
Old Oct 15, 2009 | 01:50 AM
2008SciontC's Avatar
Default little help with afr plz
Well I just installed my TT simple kit when it idles its like 11.3-12s on my aem afr gauge im on the aem fic with the map from crush. Can anyone help and tell me the right idle i think it was like 14.6 but it seems mines way off or if you have a map that might help me out its a 2008 scion tC m/t with the tial 38mm wg ( 7.25psi) spring thanks guys
Old Oct 15, 2009 | 02:10 AM
weezyfbayba's Avatar
go get it tuned or hit up elevation for a basemap but its 50$ its a really good map
Old Oct 15, 2009 | 06:07 AM
Carlanga's Avatar
You can could go to ur "F" map and substract gas on that specific block on idle and ur AFR's will go up eventually. Problem with that is that if idle is rich like that, the whole map probably is too and on top of that u will need to adjust the blocks around the one u adjust. Do you have an ScangaugeII? That's the only way u can tell if ur fuel trims are good to go. The one on my FIC doesn't give me the right fuel trims ever since I upgraded my 550 cc injectors for 700cc's for some odd reason. Maybe someone could chime in and give me some insight If I try matching them to the FIC to go to zero the car literally spits fuel. When I go by the ScanGaugeII it works flawlessly.
Once u get familiar with the tuning programs it is very easy, just remember that what I explained u can only do it when on closed loop. Once u get to open loop u have to deal with the "O" map and "F" map in tandem to get the right fuel trims and AFR's. The higher the voltage on the "O" will net u leaner AFR's. There's a sticky somewhere here that could help u understand that a bit more, check it out.
Basically, go get tuned lol
Old Oct 15, 2009 | 07:08 AM
crush02342002's Avatar
afr's will settle down after a few miles of driveing. If idle afr's do not lean out (im 100% sure that they will) you can subtract fuel from the fuel map. normal driving speeds also at first will be up and down, but after a few miles of driving youll see them settle down a bit to around 14.7 (same goes for idle). it will not be a perfect 14.7 but will hover very close to it.
now keep in mind this is just a base map so its not perfect, in boost it should run fairly rich and if it doesnt then something is wrong.
a pro tune is the way to go, i have only given maps out to get you on the road and to a tuner. That is their main function. Good luck and happy boosting.
Old Oct 15, 2009 | 11:32 AM
yeah ill try that i deff need a tune soon ill try driving it a little and see if the afrs change a bit thanks again guys i will be going to rttuning soon i hope
Old Oct 15, 2009 | 11:55 AM
ElevationTC's Avatar
First off you adjust o2 map in closed loop not open loop..
second if he pulls fuel from the fuel map and his o2 map is not right then the cars going to go all crazy..
not trying to come off as a butt, but if you dont know what your talking about dont post it! Now you have some kid who thinks open loop is cruising and he can tune himself!
what injectors are you running?
Old Oct 15, 2009 | 12:27 PM
Ok I have 550cc injectors
Old Oct 15, 2009 | 12:30 PM
also I'm at work ATM so I did not mess with anything yet
Old Oct 15, 2009 | 12:50 PM
Idk maybe I'll buy that map or somthing off you man
Old Oct 15, 2009 | 02:27 PM
mike go easy, Carlos knows what he is talking about he just got em backwards trying to explain it. it happens.
Carlos has been tuning himself for quit sometime now and has had alot of success with the FIC.
also he mentioned to use the scanegauge to find your fuel trims. fuel trims will show how off your fuel map is with your 02 map.
Old Oct 15, 2009 | 08:14 PM
bro. hit up elevation. his map he sent me worked perfect for my TT simple kit... perfect idle. perfect cruise. perfect WOT ( don't reccomend WOT untill tuned) but his was good for mine 50$ is worth knowing ur car will be safe untill tuned
Old Oct 16, 2009 | 06:03 PM
any updates?
Old Oct 16, 2009 | 06:16 PM
Yes well the shop I'm going to has their "laptop out for updates" for there mustang dyno so now I have to w8 a week but I really want to use this shop the guys a really good guy and he"s tuned 2 turbo tCs so now I'm trying to get a hold if mike for his map I sent him a pm. Car has been sitting it's only idled twice only thing is todds spipe just does not line up good only a little leak n the hot side ic pipe did not reach to well but o well I got more from TT than most people I just got robbed for a turbo, injectors, dumptube, PnP harness.
Old Oct 16, 2009 | 06:32 PM
that sucks...if its not one thing its another.
Old Oct 16, 2009 | 07:13 PM
Ok well I sent mike the money for that map just w8ing for him to email it to me we'll see tonight.
Old Oct 16, 2009 | 07:28 PM
depending on were your 02sensor location that can throw your wideband readings off (will look lean when your really ok or rich). also you said you had a leak on your hotside intercooler pipe, take care of that cause it will affect tune and drivability.
Old Oct 16, 2009 | 08:07 PM
Yeah I fixed the ic piping with a trip to homedepot lol I got that map from mike so when I go home I'll try it out.
Old Oct 16, 2009 | 08:17 PM
That map works for sure.. its worked flawless on two turbo toyota kits.
idle will be at 14.7
cruise will be between 14.5 and 14.9
wot will be around 11.5-11.7
may be a little diff because of were you live.. So i took some timing out.. remember this is a basemap.. use it as one.. do not go racing on it.. enjoy the car. and get it pro tuned! this map should save you alot of money when u pro tune as it will be very close!
Old Oct 16, 2009 | 11:00 PM
well i took it for a test drive that was scary i really think my gauge is off or somthing its now at idle around 16-17 so i shut it down but a normal driving it would kinda stay around 14-15 idk, idk if my exhaust leak has anything to do with that also the aem afr gauge is set to default any imput will help thanks
