little help with afr plz
u have an vacuum leak!!! i had the same problem. cruise would be fine.... but idle was way off.... my problem was my BOV was staying open at idle.. pos hks.... not saying that's ur problem but look for vacuum leaks!
Any leak, Wheter its IC pipe, maf leak, vacume leak..
And exhaust leak with throw off afr reading..
Very inportant you check everything man! No matter what tune u put on this will be an issue!
if thats the case i doubt its a charge pipe...sounds like either an exhaust leak causing a false reading on your wideband or something could be up with your primary 02 sensor. what codes are you throwing now?
yea my car did the same thing.... wouldint idle at all barly and was rele rele lean... i checked every vacuum line every coupler couldint find anything.... i accidently left the vacuum line off the bov after changeing it( was just changeing all line's because i was out of idea's) and the car idle'd perfect.. hooked the vaccum line up and car stalled out... my bov was staying open at idle.. . so dont give up
im still checking things i have never stalled or anything even when i drove it right now the afr is a 13-13.8 at idle. It really sucks cuz i was going to get tuned today now i gotta w8 a week ugh. I pulled the plugs once more after cleaning the old ones off and there fine now so ill just leave that for right now while i check over things. Again thank all of you for your info/tips/help. and not ripping me to bits lol
