Scion TC oil change
Old Oct 15, 2009 | 11:54 PM
v-train's Avatar
Default Scion TC oil change
Hi i was wondering if anyone could give me a detailed instruction on how to do an oil change. Ive done an oil change before in Auto class in high school but ive forgotten. so far all I remember is 1.drain oil 2. replace filter 3. put oil. 4. check oil levels. Am i missing any step? will i need to keep the engine running for step4.check oil levels? i know that the oil expands in heat so how do i check the oil level? do i need to let it cool down? do i need to check it while its running?
Old Oct 15, 2009 | 11:59 PM
B-Man92's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=127305
basically the same exact thing
Old Oct 16, 2009 | 12:02 AM
elcapetan's Avatar
no don't check while it is running because it will show as low bc it is sending it through the engine.
Old Oct 16, 2009 | 12:08 AM
my06tc's Avatar
put the car safely on jackstands...warm the car up to operating temp.....then shut the car off......take out the drain plug let it drain for about 5-10 min until its compltetly stop dripping.......clean the area nice and good.......put the plug back in.......take out the oil filter.......clean that area....put the new filter in.....now fill it up with oil..turn the car on to make sure theres no leaks for a few mins.....recheck the oil level and your god to go
Old Oct 16, 2009 | 12:13 AM
v-train's Avatar
thanks how much oil is needed for a scion tc 2010? what if i decide to go synthethic? do i just replace the oil with the same way?
Old Oct 16, 2009 | 12:46 AM
SquallLHeart's Avatar
read your owner's manual.
that's fine.
yes.
Old Oct 16, 2009 | 04:05 AM
Carlanga's Avatar
it is always good to put some oil in the new oil filter before installing it (3/4 full is ok) and put some oil in ur finger and rub it on the oil filter rubber gasket.
voodoo2crue
Mar 18, 2015 01:30 AM
cid_mcdp
Jan 5, 2015 02:45 PM
ghasper
Feb 22, 2006 12:18 AM
BlueBox
22
Nov 7, 2003 08:18 PM
BboXedin
Oct 13, 2003 07:21 AM
