Cruising afr?
Old Oct 24, 2009 | 01:50 AM
cburglb34's Avatar
Default Cruising afr?
well im on 5psi untunned and well cruising around town im at 15.3 afr bouncing around that, is this a good place to be, i have not gotten into full WOT yet because it was raining today but im sure it will be in the 10-11s
Old Oct 24, 2009 | 03:31 AM
gingles's Avatar
14.5-15.5 is fine.....i do a lean burn about 70mph like 15.3 and so on....your fine
Old Oct 24, 2009 | 03:37 AM
cburglb34's Avatar
yay,
partial throttleheck
WOT: pending
KNOCK:none that i hear..
outcome.....if the WOT AFR are good to go, then ill be running 5-6psi till i get enough money for ptuning to tune my ish
Old Oct 24, 2009 | 04:06 AM
rangerryda's Avatar
Peep the cruising video in my thread. Ultimately, you want it like this.
https://www.scionlife.com/forums/sho...d.php?t=174299
Old Oct 24, 2009 | 04:34 AM
m6ar2cel6oTC's Avatar
be careful flooring it.
Old Oct 24, 2009 | 04:52 AM
gingles's Avatar
as long as you get partial throttle down good just ease into full boost
Old Oct 24, 2009 | 05:08 AM
cburglb34's Avatar
ive opened her up almost everyday this week cept today, im not worried bout opening her up full out to see my afr, theres only one wya to find out what they are..
Old Oct 24, 2009 | 05:16 AM
gingles's Avatar
thats why you just richen the map up alot therefore not blowing your motor...id rather replace plugs then a motor
Old Oct 24, 2009 | 05:18 AM
cburglb34's Avatar
this is wat i would do, IF I HAD A FIC! lol right now on stock ecu, just tryna get some numbers (AFR's) on this size turbo, since alot of people have been asking bout running 5-6psi untunned i wanna show that afr are good and no knock, but im running an intercooler so that might be helping me not knock
Old Oct 24, 2009 | 05:23 AM
rangerryda's Avatar
Sounds sketchy anyway you look at it imo.
Old Oct 24, 2009 | 05:26 AM
cburglb34's Avatar
yes you are right sketchy, but worth it it would def help the community to know that some things can be done, if i were to blow something than i blow something...it can be repaired, but thats the only way u can do R&D
Old Oct 24, 2009 | 09:19 AM
Ace83's Avatar
Ronin Scion
my cruising afrs varies.. 14.4-15.1 depending on vacuum pressure. Im not a fan of all lean burn or all 14.7 on vacuum, as manifold pressure rises my afr gets richer, im 13-14 afr at 50-300mmHg. i like the way how the car responds and sounds with a rich tune.. towards at 0 mmhg im at around 13.0, 1-3 psi 13-12.6
Old Oct 25, 2009 | 10:30 PM
coryjames's Avatar
I run a rather lean tune with my alcohol you make better power in the top end I go a little rich right before readline I see a 11 afr it makes a mean pop lol did you tune for the eth yet?
Old Oct 25, 2009 | 11:06 PM
ScionFred's Avatar
Getting any CELs yet? I never could get rid of my P0101 with the turbo kit installed, although it ran fine with it. You may need bigger injectors because the ECU ignores the WB O2 and won't compensate for extra air in open loop. At least no more than the MAF signal and pre-programmed OL fuel table allow. I've had good success running 440cc w/o EM.
Feel free to PM me if you have any questions about what I learned during my un-tuned boostage experiment.
Oh yeah, your closed loop AFRs are normal. Even with 440cc injectors my CL AFRs run between 14.5 and 15.5:1.
Old Oct 26, 2009 | 12:08 AM
cburglb34's Avatar
yea today i noticed a 14.5-15.1 cruising but um never gotten a P0101 since im using the stock maf housing, i am getting a safc soon to help me tune some but i might wanna get injectors
Old Oct 26, 2009 | 12:13 AM
cburglb34's Avatar
P0101 usually puts u into a rich running mode kinda like limp mode, maybe this is why your guys have been able to have these rich afrs and not ish liek mine
Old Oct 26, 2009 | 12:28 AM
ScionFred's Avatar
The P0101 never changed my AFRs. I cleared it numerous times and it didn't come back immediately so I ran both with and without it.
Are you running stock injectors? If so, consider what your AFR's would be in open loop (WOT) if you added 20% more fuel with 20% larger injectors (440 vs 370).
Old Oct 26, 2009 | 12:32 AM
cburglb34's Avatar
well ima slap on a safc and richen it across the board to the max and see what my a/f ratios are....if they still arent pleasant ill go with bigger injectors
Old Oct 26, 2009 | 12:36 AM
Ace83's Avatar
Ronin Scion
afrs i posted were on 93 pump gas.. im still tuning my e83 fuel map, 32x32 resolution map takes time to complete lol.. i was thinking of doing lean burn with eth, you make good advantage of lean burn with a 105 octane coz it makes good power and helps economy too.. i think im gonna target 11.8-12 wot afrs on e83, i think it burns cooler coz its more volatile than gasoline
Old Oct 26, 2009 | 01:49 AM
ScionFred's Avatar
Good luck dude. If you can get 90% IDC at less then 5v MAF, you'll be good for <=225BHP. With 440s you could do <=275bhp.
