do I need injectors???
Old Oct 28, 2009 | 08:01 PM
Blue_TC_Man's Avatar
Default do I need injectors???
for a 9psi turbo application, do I need to upgrade the injectors?
Old Oct 28, 2009 | 08:07 PM
DezodDon's Avatar
Yes it is advisable to replace your injectors with a larger one to avoid damaging your engine I would recommend 550cc minimum.
These would work. http://www.dezod.com/pd_deatsch.cfm
Old Oct 28, 2009 | 08:54 PM
crush02342002's Avatar
what don said...lol
Old Oct 28, 2009 | 09:02 PM
ok what psi can I run on stock injectors with a tune from an F/ic?
Old Oct 28, 2009 | 09:05 PM
Tc4Eva's Avatar
Team ScionTific
Depends on what size turbo you have?
Old Oct 28, 2009 | 09:25 PM
highvoltage1's Avatar
dude if your turbo id at least run 440cc injectors. The supercharger ran 410cc and that was around 200-230whp depending on mods. I would say 550cc injectors to play it safe. 9psi would be strecthing 440cc injectors i would think plys 550cc allows for you to turn up the boost a lil more too. Play it safe!
Old Oct 28, 2009 | 09:36 PM
scikotictc232's Avatar
what about 6 psi on the ultimate, i have a t3/to4e 60 a/r cold and .82a/r hot side. have been wondering about it for a while. sorry to threadjack but its a similar question.
Old Oct 28, 2009 | 10:02 PM
your wondering what injectors?
I would say 550cc but im a almost noob at turbo. I have just done my research. If Paul Dezod says 550cc minimum id go with that. I think at 6psi 440 would be good but that seems like some big a/r numbers so you will prolly wanna turn up the boost to utilize that turbo more i would think in the future. Id say 550 but im sure someone more knowlegable will chime in soon.
Old Oct 28, 2009 | 10:36 PM
guys im just going to give a quick guide...JUST A GUIDE (for those that may want to give me crap about it)
16g turbo up to 6psi can work
t3/t4 of popular trims is a no go for stock injectors
(yes there are many variables, yes not all turbos are the same, yadda yadda freaking yadda)..lol
Old Oct 28, 2009 | 11:27 PM
B_Real45's Avatar
Why skimp on proper fueling? Do you have enough money for a rebuild? Cuz that could be the result when boosting without adequate fueling.
Stay off the boost until you get some injectors.
Old Oct 28, 2009 | 11:31 PM
Old Oct 28, 2009 | 11:43 PM
ESEMRFOZZ13's Avatar
it's sad when people throw money at a build, but then want to skip on injectors or a tune.
hey chris, im thinking 550cc but could i get away with 440cc? i mean in case i see a good deal. I wont prolly go above 10psi and will be running a t3/t04 50 trim 63a/r.
Old Oct 28, 2009 | 11:46 PM
B_Real45's Avatar
Too much flow for 440cc injectors... 10psi on that turbo with our engien should make 300whp. You need 550cc minimum - in fact with 550cc's, you won't have any more room to grow.
Old Oct 29, 2009 | 12:25 AM
i agree.
Old Oct 29, 2009 | 12:27 AM
however i think that if you added a fuel pump it may be doable but even still i would venture to guess you would be maxing out those injectors at 10psi with that turbo...this isnt set in stone, i havnt seen it personaly (440cc injectors, highflow fuel pump, 10psi), im baseing this off of other setups iv tuned and the results of that.
Old Oct 29, 2009 | 12:42 AM
FreedomOne's Avatar
I just started my research on a turbo for my ride, and I already know that I'm getting 550cc injectors. Like the others have said, play it safe. Your going to be investing a lot of money.
damn ill just wait a bit longer than. i need a waste gate couplers and injectors and my set up is golden. than im gonna need a clutch for sure.
Old Oct 29, 2009 | 12:51 AM
also if i may suggest that if you think you may want to go higher later you may want to go up to 700cc injectors. just a thought. its just cheaper in the long run cause 700cc's are roughly the same price. however you go too high and you may end up sacrificing comfort. Idle may be harder to tune to stock feel. again just a thought
Old Oct 29, 2009 | 12:52 AM
B_Real45's Avatar
Buy my 630cc injectors! 275whp at only ~60% duty cycle.
