Max Boost
Old Oct 29, 2009 | 01:55 AM
BlkRS5's Avatar
Default Max Boost
So what's the max I can boost a stock 09 motor. I've tried searching but only found max for supercharger and saw alot of different turbo setups.
Old Oct 29, 2009 | 01:57 AM
cburglb34's Avatar
at around 340whp id start looking for a spare block to build...
and as far as BOOST it all depends on size of turbo and how good your tune is....stock block 12 psi is where most would stop and look for a spare block or rods n pistons
Old Oct 29, 2009 | 02:00 AM
BlkRS5's Avatar
On a desendants full kit it pre tuned what's the max I can up the psi. Not really planning a dyno right now (short on cash).
Old Oct 29, 2009 | 02:02 AM
crush02342002's Avatar
talk to mike (elevationtc) he has gone the furthest on stock block that i know of that is on the forum.
cburglb34's Avatar
this isnt a factory turbo ca ru cant just up the boost and not retune...
everytime u wanna up the boost u gotta retune same goes for when u change your exhaust when turbo
Old Oct 29, 2009 | 02:35 AM
scion_andrew's Avatar
Are u saying u wanna run lot of boost without a tune?
Old Oct 29, 2009 | 02:45 AM
weezyfbayba's Avatar
im at 12 psi not and dont plan on boosting any higher untill i can afford to do a build
Old Oct 29, 2009 | 02:50 AM
cburglb34's Avatar
elevation blew his motor at 362hp
Old Oct 29, 2009 | 02:57 AM
m6ar2cel6oTC's Avatar
just to be safe dont pass 300whp & 300trq
Old Oct 29, 2009 | 03:03 AM
cburglb34's Avatar
this
Old Oct 29, 2009 | 03:06 AM
i doubt im even there.. small cold side on my turbo ftl
Old Oct 29, 2009 | 03:32 AM
you might be close weezyf, i think you are knocking on 300whp range...
Old Oct 29, 2009 | 03:37 AM
topekatc's Avatar
something else we need to no is if your running automatic or manual transmission...if your on an auto don't go past 7-8psi unless you build the tranny....on manual most do stop at 10-12psi
Old Oct 29, 2009 | 04:11 AM
gingles's Avatar
coryjames is at 360hp or 380 on a stock motor
Old Oct 29, 2009 | 04:15 AM
SoFloTC's Avatar
lawl
Old Oct 29, 2009 | 04:41 AM
Ace83's Avatar
Ronin Scion
it really not on how much boost.. its how much power the car handle on a good tune that doesnt detonate or preignite.. considering both tunes are good it doesnt matter much if you push 14 psi or 16 psi to reach a the breaking threshold of stock motor maybe its around 350-380 range.. oh bluesciontc i think did 400hp on stock motor i think it was 16 or 18 psi, then he built his motor
Old Oct 29, 2009 | 04:48 AM
gingles's Avatar
how long did blue's last? i know i was running 16psi on my stock motor but had a 57trim turbo
Old Oct 29, 2009 | 04:57 AM
Hix's Avatar
Hix
Pffft I wanna go 10-11 on my auto. BLOW IT UP!!!!
Old Oct 29, 2009 | 04:59 AM
SoFloTC's Avatar
bro just crank the boost up to 25 psi untuned... u should be good to go
Old Oct 29, 2009 | 05:00 AM
cburglb34's Avatar
lol^^^ auto trans will start to slip like a oldman on an icey day at 250hp.....gl
