Is the 2010 xb going to be included in gas pedal recall?
Old 11-29-2009, 07:14 AM
Joeynenj's Avatar
Default Is the 2010 xb going to be included in gas pedal recall?
Hi, i've been reading that some toyota products has a issue with the gas pedal getting stuck. Altho i have not read anything about the 2010 xb, i was wondering if this model will be included in any recalls since its toyota built and may share the same parts as other models. Anyone have info? Thanx
Joeynenj is offline
Old 11-29-2009, 12:13 PM
davedavetC's Avatar
it was a floor mat recall. and it has been solved, what the problem was in all reality is people were doubling up on floor mats and they would slide forward. and people were not using the clips that held the floor mats in so again they would slide forward.
as for toyotas fault, they did have a batch of floor mats that were too thick which got stuck under the floor mat but now they are resolved
davedavetC is offline
Old 11-29-2009, 02:17 PM
strtrcril87's Avatar
No, they are resolving the problem in the toyotas by installing a shorter pedal. They've already started doing that in japan and are going to here at the beginning of 2010.
strtrcril87 is offline
Old 11-29-2009, 03:19 PM
kidd's Avatar
if you don't want to die? keep all obstructive object away from the gas pedal.
kidd is offline
Old 11-29-2009, 03:21 PM
jnaval's Avatar
The majority of those problems were with their Lexus brand.
jnaval is offline
Old 11-29-2009, 08:54 PM
AAG
DeepSouth Scions
AAG's Avatar
I've never once had a problem with the floor mat getting caught on the pedal. If you clip it down properly you never will.
AAG is offline
Old 11-30-2009, 09:19 AM
XBinRochester's Avatar
Since the 2009 XB was not part of the recall, I would have to assume that the 2010 would also not be part of it.
XBinRochester is offline
Fisqual
09-22-2015 05:51 AM
ninoTc
01-24-2015 05:02 AM
blueonyxxB
01-21-2004 05:52 AM
blumonde
01-19-2004 11:47 PM
insane451
12-10-2003 11:36 PM
Quick Reply: Is the 2010 xb going to be included in gas pedal recall?
