Pulling wires through grommet
Old Dec 2, 2009 | 02:15 AM
05erTcRider's Avatar
Default Pulling wires through grommet
Im trying to pull some wires through the rubber grommets on my doors, i havent replaced my door speakers so the stockies are still riveted in. Im wondering if anyone has a trick to getting them through or anything like that, im having a hard time figuring out how to get em through.
Im trying to get the BMW style door handle accents up and running but im kinda hung up at this step, any help is appreciated, thanks guys.
Old Dec 2, 2009 | 04:49 AM
Ace83's Avatar
Ronin Scion
you cut a bit of the grommet to make the hole bigger, you can use the hanger method.. or a long screw driver or prybar.. what you do is tie or tape or hook the wire to the long object then stick it through the firewall, then once its on the other side of the firewall you can untie or remove the wire and you're done..
Old Dec 2, 2009 | 05:21 AM
donnyp05tc's Avatar
Ace83 is right on! Follow what he said.
What always worked best or me is the hanger method and taping the wires to it, then pulling it though. Helps to make a small slit with a knife in the grommet first though. Easier to poke hanger through.
Old Dec 2, 2009 | 06:08 AM
KaneoheKoa's Avatar
A squirt of silicone spray does wonders, too. Just cover anything you don't to get sprayed.
Old Dec 2, 2009 | 02:04 PM
Chuckie's Avatar
they make a tool called a wire grabber...autozone 6 bucks...does wonders
Old Dec 2, 2009 | 10:01 PM
word thanks guy
Old Dec 3, 2009 | 12:38 AM
mattieg's Avatar
you can also use a large zip tie
Old Dec 3, 2009 | 01:27 AM
nodsetse's Avatar
What guage wire are you using? If mandos was able to get 12ga through there, smaller wire shouldn't pose an issue...
Old Dec 3, 2009 | 02:08 PM
Ace83's Avatar
Ronin Scion
mando i think used 0 or 1 gauge and fit like 2 or 3 of em lol
Old Dec 3, 2009 | 06:28 PM
Luc1f3r's Avatar
the hell would you need 0awg ran into your doors for!?
Old Dec 3, 2009 | 06:46 PM
Luc1f3r's Avatar
Old Dec 3, 2009 | 06:48 PM
beandip007's Avatar
maybe to weld with...duhh
Old Dec 4, 2009 | 03:38 AM
Swbari00's Avatar
Not sure how the TC doors are compared to the XD doors, but if they are at all similar, I just unplugged the wires from inside the kick panel and pulled the whole grommet out of the door. Was pretty easy the run the wires through that way.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
TCnewguy
Scion tC 2G ICE & Interior
11
Feb 22, 2015 04:18 AM
TCnewguy
Feb 16, 2015 03:50 AM
randode
44
Jun 29, 2004 04:19 PM
sapdawg11
19
Feb 29, 2004 08:43 PM
