Random multiple cylinder misfire detected
Old Dec 6, 2009 | 05:12 PM
tc1003's Avatar
Default Random multiple cylinder misfire detected
How can I narrow down the cause of this? I have already changed the plugs after that I’m not sure where to go. Could this be related to afr because I have to connect the gauge still so I don’t know as of now the afr. In addition if it’s helpful the car has a issue with its idle where it goes up and down and never seems to be stable.
Attachments are the error codes, freeze frame data and emanage graph.
Attached Thumbnails Random multiple cylinder misfire detected-framedata.jpg   Random multiple cylinder misfire detected-codes.jpg   Random multiple cylinder misfire detected-graph.jpg
Old Dec 6, 2009 | 05:14 PM
dave2610's Avatar
running to rich would be my guess
Old Dec 6, 2009 | 05:31 PM
Blue_TC_Man's Avatar
get an AFR gauge. and your either rich or lean.
what did your old pugs look like when you pulled them
Old Dec 6, 2009 | 05:41 PM
tc1003's Avatar
Plugs were black. I have the gauge installed I just need to get the welding done to finish it.
Old Dec 6, 2009 | 06:17 PM
Ace83's Avatar
Ronin Scion
yeah check your afrs, too rich and too lean will cause misfire. check you plugs too if theyre fouled and also the gaps
Old Dec 6, 2009 | 06:18 PM
dave2610's Avatar
Check out this chart which did your plugs look like
http://www.ngksparkplugs.com/tech_su...qs/faqread.asp
Old Dec 6, 2009 | 06:23 PM
cmcpride's Avatar
Default misfire
how many miles. are you running with cold air intake ? are you useing maf if so check maf it might be dirty. your readings looks ok short trim coo. long trim within specs. you may also have a vacuum leak . that will also cause unstable idle. and incorrect a/f readings. how about throttle duty %
Old Dec 6, 2009 | 06:31 PM
yeah your rich
Old Dec 6, 2009 | 06:38 PM
tc1003's Avatar
Like the second image except the Insulator was still white.
Old Dec 6, 2009 | 06:43 PM
dave2610's Avatar
maybe just a little rich then. Id say its tune related
Old Dec 6, 2009 | 06:52 PM
tc1003's Avatar
miles 69000, maf replaced same issue, vac leak is a possible but I have not yet found one and I did check. I hope the attachment answers the question about throttle duty I put everything in there.
Old Dec 6, 2009 | 07:04 PM
WillyB's Avatar
A lean condition would sputter, That's when you would need to clean/change a MAF or even O2 sensors. Rich is inconsistent idle, and surges. what's the CEL code number?
Old Dec 6, 2009 | 07:07 PM
tc1003's Avatar
P0300
P0302
P0303
P0304
By this it sounds like rich thats what its doing.
Old Dec 6, 2009 | 07:10 PM
WillyB's Avatar
Sorry didn't see the Chart. I would put my money on O2 sensors or Fuel injectors, could also be Coil packs. I work on my own cars, and i always seem to change Plugs, and Coils at 70,000 miles.
Old Dec 6, 2009 | 08:24 PM
dave2610's Avatar
my 2 cents- i had similar issues with the misfires and inconsistent idle i was running rich
Old Dec 7, 2009 | 12:29 AM
cmcpride's Avatar
have you checked your compression yet. if so where is it at?
Old Dec 7, 2009 | 02:25 AM
tc1003's Avatar
Thats what im leaning towards now I just have to get the gauge welded in and connect it to the emanage.
Old Dec 7, 2009 | 02:26 AM
tc1003's Avatar
Have not checked yet.
Old Dec 7, 2009 | 02:31 AM
tc1003's Avatar
Also is gap on the plugs that important that it could cause this. The plugs are NGK iridiums I think the gap out of the box is .44 I got injector cleaner in the tank now, guess I will se if that helps. I also notice when the idle is messy raising the throttle a bit will have the same issue bouncing around so its not just idle.
Old Dec 7, 2009 | 02:35 AM
tc1003's Avatar
Also having the injector cleaner in the tank made the jumping around worse. I have not got through the tank yet to see the end product but for the most part it sounds like a fuel issue correct?
