Boosting and super lean
Old Dec 8, 2009 | 12:10 AM
Rydrdg's Avatar
Default Boosting and super lean
Ok this morning car start car drove and afr was 14.7 and 15s cruising, when in boost AEM wideband afr reads lean with one red bar and off chart...I tried loading map still same, the car still run perfect. I check for vac leaks cant find any. anybody have suggestion why my wideband reading superlean in boost...
Old Dec 8, 2009 | 12:17 AM
cburglb34's Avatar
what kit, injectors and tune u got?
Old Dec 8, 2009 | 12:19 AM
ElevationTC's Avatar
no.. you should turn ur car off. and stop driving it!
check ur wideband make sure its working. if it is.. do not hit boost
Rydrdg's Avatar
greddy turbo kit 550 injectors greddy emu unit tuned and driving for 1 year
Old Dec 8, 2009 | 12:22 AM
Rydrdg's Avatar
I check wideband everything look fine only when in boost just super lean
crush02342002's Avatar
colder weather can have a fairly large impact on tune...that may not be the only thing but its something to look into exp if you were tuned during the summer. small vac leaks can do it as well. large vac leaks tend to mess with the maf so much that it just goes all wiered on ya.
im banking on the issue to be more than one thing.
cburglb34's Avatar
try to reset your ecu, cuz closed lopp fuel trims like to find their way into open loop and well if u have a -20 fueltrim well yea...
Old Dec 8, 2009 | 12:23 AM
cburglb34's Avatar
also speaking if your using the emanage blue count that as the problem cuz it tuned off the maf and well now that its colder readings are different
Old Dec 8, 2009 | 12:24 AM
exhaust leak is a very likely culprit as well
Old Dec 8, 2009 | 12:25 AM
cburglb34's Avatar
so many factors
Old Dec 8, 2009 | 12:26 AM
Rydrdg's Avatar
I drove last winter it was fine and i was tune in summer.
bdis3's Avatar
Chances are if its reading lean in boost, your actually lean in boost. Add fuel if you tune yourself, until you find the problem (if there is one)
Old Dec 8, 2009 | 12:27 AM
Rydrdg's Avatar
Did that still same
Old Dec 8, 2009 | 12:28 AM
weezyfbayba's Avatar
BUY A HONDA!
get a hatchy a gsr swap 75 shot. call it a day
Old Dec 8, 2009 | 12:29 AM
cburglb34's Avatar
Originally Posted by weezyfbayba
BUY A HONDA!
x2
Rydrdg's Avatar
Usually lean or rich condition set off my cel like before but this time it didnt Im think the wideband could be going bad I just got it this year..
BUY A HONDA!
Bro you drive an XA, what are you doing in the tc forums
cburglb34's Avatar
except for this part, i beat one with same setup when i wa sjust on 4.8psi and open downpipe haha, and no it wasnt a driver mod issue
Old Dec 8, 2009 | 12:31 AM
Rydrdg's Avatar
BUY A HONDA!
I snack on Honda
