Rear Emblem removal
Old Feb 10, 2005 | 02:37 AM
dthree36's Avatar
Default Rear Emblem removal
Hello All,
I have a Scion XA that i would like to remove the rear emblem. I searched the posts and found that the TC's rear emblem is held on by two sided sticky tape. Is the emblem on the XA the same? I would think so but before I take a screw driver to the emblem and damage it, I would like to know for sure. How about the small XA emblem?
Thanks
Old Feb 10, 2005 | 02:48 AM
FrankenScion's Avatar
They should all be the same. If you warm it up with a hair dryer for a while it comes off easier. Also, make sure you wrap the screw driver with a towel or something to keep from scratching anything.
Old Feb 10, 2005 | 02:49 AM
dthree36's Avatar
Thanks,
D
Old Feb 10, 2005 | 03:07 AM
JDMbB's Avatar
i believe theres a write up in the tech section. u should check it out. and dont use a screw driver. use dental floss or fishing wire instead.
Old Feb 10, 2005 | 03:09 AM
Budman1's Avatar
After heating it up a little with a hair dryer, wrap some dental floss around a couple of small pieces of wood and slide it behind the emblem. After you get it off, use some googone or similar product to remove any remaining adhesive.
Old Feb 10, 2005 | 03:17 AM
scion909's Avatar
Here's a link for you:
https://www.scionlife.com/forums/viewtopic.php?t=20747
***************************LOCKED***************************
kleecker
Jan 9, 2015 02:26 PM
nacy333
44
Oct 4, 2009 11:18 PM
jonathan
Dec 1, 2003 11:28 PM
