Fog Light Replacement
Old Dec 23, 2009 | 01:36 PM
WiCKD_tC's Avatar
Unhappy Fog Light Replacement
So as everyone knows there was a blizzard out in the mid-atlantic. Well the roads still suck and not many are plowed there are potholes everywhere and my right Fog Light is no longer working (probably killed the bulb).
I also have a ground effects kit on my car that Scion sells, it's a 2006. My question is, is it possible to get to the bulb with my hand take it out and put a new bulb in. I hear Scion charges an arm and a leg to replace fog lights and I wanted to know if it was possible to do with no tools at my hand to do it.
Any help would be appreciated.
Old Dec 23, 2009 | 01:50 PM
Jon's Avatar
Jon
Moderator
Moderator
You may be able to reach behind the bumper from the top and take the socket out. Or you could just push the bottom grille out and do it that way.
Old Dec 23, 2009 | 02:00 PM
WiCKD_tC's Avatar
Do you happen to know what bulb it takes?
Old Dec 23, 2009 | 02:01 PM
Jon's Avatar
Jon
Moderator
Moderator
Old Dec 23, 2009 | 02:39 PM
WiCKD_tC's Avatar
I'm assuming to pop out the grille I would need a special tool to do this, if so which one? I'll see if my skinny arms can reach the socket, but probably wont.
Old Dec 23, 2009 | 02:44 PM
Jon's Avatar
Jon
Moderator
Moderator
Nope. Just a flat head screw driver. There are honeycombs around the edge of the grille that aren't open and that's where you place the screw driver. You probably could just push it with your hand though.
Old Dec 23, 2009 | 02:48 PM
WiCKD_tC's Avatar
Nice, will try in the freezing cold weather when I get off work this afternoon. Appreciate it Jon!
Old Dec 23, 2009 | 09:48 PM
WiCKD_tC's Avatar
Well 1 hand can reach the light, but I can't fit two hands down to release the clip to take the bad bulb out and put a new one in. I don't think pushing the grille out will help since I have a ground effects kit on I won't be able to push it back forward. :/
Any ideas?
Old Dec 23, 2009 | 09:52 PM
Jon's Avatar
Jon
Moderator
Moderator
I have the ground effects kit as well. Usually I push the top grille out and use that opening to reach down and push the bottom grille back in.
Old Dec 26, 2009 | 03:26 PM
cweckel2000's Avatar
You shoudln't have to pull any clips to get the bulb out of the light housing, just turn the bulb to one side (its different depending on what bulb it is) and it slides right out. Then you can atleast pull the wire w/ the bulb up higher to get the bulb out of the socket. Its a pain but doable.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
carid
Jan 8, 2015 11:33 AM
TheTripleC
Jan 4, 2015 06:46 PM
umnitza
Dec 1, 2014 06:26 PM
