Smoothie rims with Baby Moon hubcaps and trim rings
Old Dec 26, 2009 | 05:01 AM
otis06's Avatar
Default Smoothie rims with Baby Moon hubcaps and trim rings
This subject may have come up before, so I apologize in advance if we're going over old territory. I have a 2006 xA. I want to run a plain steel rim, a little deeper than stock maybe, with a baby Moon hubcap (or other smooth chrome cap) and possibly chrome trim rings. Yes, I'm an old guy...I like classic rims, and that's what this combination is. Classic. Where can I get such a combination? I know stock rims won't work, but does anyone sell this? Can I order it powder coated in my color choice? Can I get it in a larger diameter than the stock 15", and slightly deeper without making the tires rub on the inside of the fender wells? Is anyone else running anything similar?
Old Dec 26, 2009 | 06:46 AM
burstaneurysm's Avatar
Well... you have some options. You can get the stock steel wheels widened, if you so desired, you have full control of the offsets and width to ensure that you don't have problems with rubbing.
If you didn't want to do that you can get trim rings that will fit the stock wheels. I currently have that on my car as my winter setup. It's inexpensive and will give you most of the look I think you're going for.
Old Dec 26, 2009 | 09:24 PM
RedneckwithanxB's Avatar
The stainless trim rings can be purchased at NAPA, and you can also get nice centercaps for the steelies as well
Old Dec 29, 2009 | 01:57 AM
bbszero's Avatar
Diamond Racing wheels, they'll do any size/offset steelie you want.
http://www.diamondracingwheels.com/
Old Dec 29, 2009 | 02:13 AM
But I've heard that the Diamond wheels aren't really strong enough for daily use (bend easily, etc...)
Old Dec 29, 2009 | 12:58 PM
bbszero's Avatar
Oh, I've never heard any complaints, but only seen a few guys roll them. Probably cheaper to have the factory wheels widened anyway.
Old Dec 29, 2009 | 04:08 PM
sdsnybny's Avatar
There are two manufactures that make steel smoohtie's with 4x100m PCD's both will need a spacer in front to clear the caliper. more pics here in post #94 http://www.clubxb.com/forums/f5/sid-s-xb-166-5.html when I think of the other company Ill post. Both brands were available at Les Schwab last time I checked, you have to go through there big book to find them.
http://www.alliedwheel.com/wheel.php?name=Smoothie
OK here is a shop that custom makes them
http://www.earlywheel.com/index.html
Old Dec 29, 2009 | 05:19 PM
vettereddie's Avatar
Yeah, I'm running an eBay chrome trim ring on my steelies and it's holding up well. The center caps, not so much. NAPA had them zinc coated so they were dull. I sanded off the zinc and polished it, then hit it with a few coats of clear for alloy wheels. The clear must have chipped, because after this last snow and salt one of the caps is rusting pretty bad. Now I'm thinking of getting them powdercoated or just chromed to match the lip. No corrosion on the lip or gorrila lugs yet.
Another tip, wash and then wax your steelies before adding the ring, makes them easier to clean and shine great.
Old Dec 30, 2009 | 09:06 AM
bB2NER's Avatar
Music City Scions
Steve, how much do those smoothies run each? They look absofreakinlutely awsome man!
How much spacer needed to clear calipers? Thanks
Old Dec 30, 2009 | 01:17 PM
sdsnybny's Avatar
last time I checked they were about 75-100 each and Sid's thread from ClubxB has the specs, he went with 25mm bolt-on's, but you might get away with 10mm hub centric's and longer studs. they are low offset to begin with so there gonna poke a little. His build thread has lots of good shots.
Hydryman
Feb 23, 2016 03:35 PM
umnitza
Sep 1, 2015 08:06 PM
10spokess
Aug 16, 2015 02:50 AM
JoggerFogger
Photography & Video
Jul 27, 2015 09:34 PM
Scionxa180
Jul 25, 2015 05:22 AM
