HID's w/Sonar Projector Headlights?
Old Dec 30, 2009 | 02:53 AM
shortbusxb's Avatar
Default HID's w/Sonar Projector Headlights?
Is anyone here using HID's with their SONAR projector headlights? Right now I'm looking at HIDEXTRA.com. Is the HID bulb size the same for these headlights, as they would be with OEM headlights? Pictures of your lights would be great!
Am I going to need a H4 or 9003 bulb size?
Appreciate the help.
Old Dec 30, 2009 | 04:02 AM
RedneckwithanxB's Avatar
Sonars are a 9006 and yes, you can run HIDs in them, I did for almost 2 years
Old Dec 30, 2009 | 07:52 AM
shortbusxb's Avatar
Don't you mean 9003? 9006's are for the fogs.
Old Dec 30, 2009 | 07:57 AM
EAmon's Avatar
no they are 9006 for sonars, stocks are 9003(H4)
Old Dec 30, 2009 | 08:04 AM
If I meant 9003 I would have said 9003... they are 9006
Also, here is the cutoff on them with 8000K HIDs
Old Dec 30, 2009 | 06:05 PM
burstaneurysm's Avatar
Sonars are 9006 low beam and HIDs work without issue. In fact, it's the only way I'd recommend running them.
Old Dec 30, 2009 | 08:17 PM
Zman's Avatar
I just got a kit on ebay for the Sonars. *crosses fingers*
Any special place to mount the ballasts from people that have HIDs?
Old Dec 30, 2009 | 08:18 PM
shortbusxb's Avatar
Awesome. Sounds good then. Before with the OEM, I would get flashed from time to time. I loved the HID look and miss having them. Now that I have projectors, I'm anxious about getting them again.
Old Dec 30, 2009 | 08:19 PM
shortbusxb's Avatar
In my Gen1 xB, I placed them on top of each fender.
Old Dec 30, 2009 | 08:50 PM
Zman's Avatar
Thanks. I can't wait until it gets warm so I can do this.
Old Dec 30, 2009 | 09:04 PM
vettereddie's Avatar
9006 for low beam, please don't get the high beams in HID, it will tick off other drivers since the high is not a projector housing. I wouldn't go above 6k, I got them and want to swap for 4.3k since the Sonars I got already have a blue tint on the projector.
I got the slim digital ballasts, mounted them on the shelf on the side in front of the strut towers, just used 3M red tape and they haven't come loose yet.
Old Jan 1, 2010 | 05:48 AM
Zman's Avatar
What's the high beam bulb size if you don't mind me askng?
Old Jan 1, 2010 | 07:28 PM
Highs are H1. You should never use HID for highs since the bulbs need to warm up after they're ignited. Highs don't get used super often for long periods of time and the constant on/off will kill the bulbs prematurely, not to mention they won't always get to full luminance before you have to flip back to lows.
If you have OEM housings though, you can get bi-xenon bulbs in H4 that will give you both low and high operation with the same HID bulb, they're awesome.
Old Jan 1, 2010 | 08:56 PM
daneisthegreatest's Avatar
i have the bi-xenon bulbs in my bB housings and i dont know what i would do without them.
Old Jan 2, 2010 | 02:32 AM
Zman's Avatar
I only got HIDs for the low beams anyway.
Old Jan 4, 2010 | 02:20 PM
I'm sure the bi-xenon look good but stay away from them unless it's a show car. The stock xB reflector housings don't cut the beam off cleanly and give a lot of glare and hot spots, making it like you always have your highs on to the driver ahead of you in his mirror. The Sonar projectors actually have a metal plate behind the lens that provides the clean cut-off. I've seen some motorcycles use what's called a casper shield that does essentially the same thing, but they're hard to find. They look like this:
Old Jan 4, 2010 | 05:24 PM
SentraSE-R's Avatar
I've got projectors in my '06 RS3.0 with stock bulbs. Since HIDs have different filament placement, they'll scatter light. If you switched to HIDs with projectors, do you get flashed by other drivers? How much more often? Once a night, every night, all the time?
Old Jan 4, 2010 | 06:59 PM
With the Sonar's, I've never been flashed. The filament placement does make a hotspot with each bulb, but it stays below the cut-off. I've never been flashed, the biggest problem is that the cut-off is so good, you can't read street signs, and speed limit signs are hard to see at night because there is no light to reflect that high. Since the cut-off is due to a metal plate between the internal reflector and the lens, it is not affected by the filiment placement.
I'll try and post pics this evening.
Old Jan 4, 2010 | 07:48 PM
shortbusxb's Avatar
Thanx for the advice/suggestions everyone. I ordered my 6K HID Kit from www.HIDEXTRA.com today. Should be delivered in a couple days. I'll try and post pics when I get them.
Old Jan 14, 2010 | 10:59 PM
SEXB909's Avatar
shoulda called me Ty, I thought you knew i had hid's in my Sonars.
