battery or alternator
Old Jan 5, 2010 | 02:05 AM
allisonapple's Avatar
Default battery or alternator
Today my poor scion died. I stopped to fill up and when i went to turn it on, the gage didnt move and the lights came on on the panel and my headlights were dim. Some say alternator some say battery... Anyone out there know which is right?
Thanks
I have 60k miles and i'ts an 06.....
Old Jan 5, 2010 | 02:23 AM
draxcaliber's Avatar
okay...if you jump start the car, and it continues to run without dying, it is probably the battery.
if you jump start it and it slowly runs out of electricity and dies, then it is the alternator not recharging the battery.
do you know how old the battery is?
Old Jan 5, 2010 | 02:44 AM
its the factory battery. I once had an issue and had to jump the car and they told me that the battery in the car is a standard forever life battery.. does that make sense?
thanks so much.
Old Jan 5, 2010 | 09:45 AM
helloninja's Avatar
Another easy check is once started, disconnect the battery... if car runs the alternater is good, if it shuts off its bad...
Old Jan 5, 2010 | 09:50 AM
jct's Avatar
jct
i replace my car batteries every 5 years even if its not needed i still change it
Old Jan 5, 2010 | 12:06 PM
jbae1221's Avatar
poor scion.. also see if the battery light is on.. if it is then most likely the alt if not then the battery
Old Jan 5, 2010 | 03:32 PM
it's the alt.. thanks for all of your input... poor scion
Old Jan 8, 2010 | 06:47 AM
bB2NER's Avatar
Music City Scions
I was gonna say... I'm still on my orginal batter since June 04' and it's still going strong.
Glad you know for sure now.
Old Jan 8, 2010 | 03:02 PM
Default alls good
would you believe that there was nothing wrong with the scion. The battery passed tests, the altinator passed tests, and when put back together my baby is running fine!!!
There is a light on that I dont know about tho... the check engine light is on and someone said it's electrical, could that have been the issue?
Thanks all. Glad to be on this site.
GO SCION!
Old Jan 8, 2010 | 03:23 PM
well, pull the CEL and find out. as for the problem start, could you have just left something on that drained the battery?
Old Jan 8, 2010 | 09:49 PM
bB2NER's Avatar
Music City Scions
Sounds like something drained it down then. Now that my battery is getting older I throw a Battery Tender on it about once a week just to make sure it stays fully charged. It sits in the garage about 95% of the time.
Def check out what code the comp. is throwing and get it fixed. Make sure to erase the codes once the repair is done.
Old Jan 9, 2010 | 03:13 AM
got_bass's Avatar
Wink yep yep
I work on cars for a living, and this is truly one of the easiest and quickest tests you can do. Also, you could go to any autozone or schucks and they can test both your alternator and battery for free. (because they're hoping you'll buy whatever's broken from them)
Good luck!
yupinmytC
22
Jul 27, 2024 07:08 PM
Geedavell
Scion xD ICE & Interior
Sep 28, 2015 01:33 AM
spharr62
Sep 20, 2015 01:44 AM
SJMiller
Sep 12, 2015 06:33 PM
SFXB
Jul 9, 2015 11:00 PM
