dezod+ kaminari hood= fail?
Old Jan 16, 2010 | 07:38 PM
azndragon669's Avatar
Default dezod+ kaminari hood= fail?
hey does anyone have a problem with their dezod turbo kit hitting their kaminari reverse cowl hood?
Old Jan 16, 2010 | 07:46 PM
ElevationTC's Avatar
My ptuning kit dont hit my kami hood.. Shoot even my custom top mount did not..
Maybe You + interweb = FaiL?
Old Jan 16, 2010 | 08:11 PM
GQQSE13's Avatar
im pretty sure that the kamanari hood wont work with a dezod kit, unless it has some sort of modification to the hood or something like that from what someone told me, but i could be wrong
Old Jan 16, 2010 | 08:51 PM
alienvictim's Avatar
^lol grow up
give a set of hood spacers a try. you can get some cheap ones at lowes for 30 cents each.
than if your satisfied get a set of the more expensive ones. thats how a lot of nissan and
honda guys clear engine swaps.
good for clearance but also may be useful to give additional turbo cooling on the up side.
Old Jan 16, 2010 | 08:57 PM
Originally Posted by alienvictim
^lol grow up
I would highly suggest not doing this, as the kaminari hood is not oem, its strength is already weaker then an oem hood...Putting spacers is not only a great way to make your car look rice as hell, But will also add stress to your hood latch..
Again i would spend some time searching as this has been answered.. I would just be careful who you take advise from..
hood spacers
Starts with hood spacers end up like this
If you have a kami hood you already have a great start! Great peice and works with dezod kit.. They have one on one of the employee cars!
Old Jan 16, 2010 | 09:04 PM
Since you and the other guys who were to busy saying grow up can not use a search button.
Here
https://www.scionlife.com/forums/sho...dezod+kaminari
It fits.. Most people use dynamat or some sort of heat wrap..
Old Jan 16, 2010 | 09:40 PM
Ace83's Avatar
Ronin Scion
hood spacer is a no no.. if it doesnt fit without it, it might fit with those spacers but your turbo will still burn cf hood. As for I dezod kit, it should fit but make sure you put some turbo blanket and some heat insulating hood liner to protect the hood
Old Jan 16, 2010 | 10:13 PM
Maybe You + interweb = FIAL?
ok smart ___ were not talking about the p tuning kit anyways. second learn how to type cause your spelling is pretty fail.
anyways its the oil line that is hitting the hood. any suggestions
Old Jan 16, 2010 | 10:25 PM
dave2610's Avatar
just get some heat shield for the hood
Old Jan 16, 2010 | 10:26 PM
dave2610's Avatar
you removed the oem heat shield right?
Old Jan 16, 2010 | 10:29 PM
my hood isnt being melted...the oil line is hitting the hood thus cracking the inside of my hood
Old Jan 16, 2010 | 10:54 PM
Ace83's Avatar
Ronin Scion
im sure you could do a way with the oil line, maybe clocking the center section of the turbo would help
Old Jan 16, 2010 | 11:06 PM
dave2610's Avatar
yup just route the line differently
Old Jan 17, 2010 | 12:43 AM
thendawg's Avatar
Had this happen on one of the tc's here with a top mount mani - had to change the oil fittings to make the oil line sit down lower on the CHRA also clocked the CHRA about 10-15* - before we figured it out his made a nice little notch on the inside of his cf hood lol.
Old Jan 17, 2010 | 02:22 AM
i dont agree on the hood spacers but cf burn does worry me and the insulation is a great idea. i worked doing a lot of aircraft repair at ATS in Washington. something i have yet to see is someone using a high temp silicone reinforced fiberglass sheet.
they use it in the wheel wells of boeing and mcdonald douglass airplanes as a firewall supplement.
i have a patch of it about 1 yrd x 1yrd if anyone can use it? it is capable of withstanding 550℃ which is 1022 degrees Fahrenheit.
this crap is expensive but i will let it go for 20 bones.
http://www.newfire.biz/htm/scff.asp
Old Jan 17, 2010 | 04:00 AM
Tomas's Avatar
Admin Emeritus
The majority of posts in this thread have been deleted because the sole purpose of many of them was purely to attack other members and disrupt the thread. Those left are more or less on-topic.
The OP came here to get a simple question answered. Instead a group of thugs jumped him. There is no excuse for that and it is unacceptable behavior.
Now that the thread itself is pretty much cleaned up, I'm going through things again to see what warnings and infractions are needed.
Pitiful.
yupinmytC
22
Jul 27, 2024 07:08 PM
mudguy
Oct 22, 2015 04:31 PM
Scionxa180
Scion xA Aero & Exterior
Sep 24, 2015 10:58 PM
mikeac
Sep 15, 2015 03:24 PM
Btp907
Sep 15, 2015 02:54 AM
