Power Steering Delete/Removal/Tuck
Old Jan 21, 2010 | 08:42 PM
johnhawkins's Avatar
Default Power Steering Delete/Removal/Tuck
I have seen a few tCs with deleted or tucked power steering.
Can someone provide a list of things/parts that are necessary to delete the power steering?
Also, If I just wanted to hide the resevoir behind the engine rigth near the power steering pump is this possible? Would it be ok to have the resevoir that low?? Any tips/hints/help is welcome. Thanks.
Old Jan 21, 2010 | 09:25 PM
yellowxhoodie's Avatar
well first off...
why?
are you doing this for looks or to free up HP?
because if its to free up HP, just stop. its not even worth it.
and have you ever driven a car with no power steering?
Old Jan 21, 2010 | 09:33 PM
TCpete's Avatar
no guy... no
Old Jan 21, 2010 | 09:41 PM
Its DEFF for looks lol and yes my CRX had no power steering - What about moving the resevoir to where the pump itself is (behind the engine)
Old Jan 21, 2010 | 09:51 PM
i moved mine.
youll be fine.
Old Jan 21, 2010 | 09:57 PM
awesome thanks alot
Old Jan 22, 2010 | 12:51 AM
ESEMRFOZZ13's Avatar
if you do remove the p/s, make sure your moving when turning the wheel. it makes it easier on things. my last ride rolled without it and i loved the feel of it.
Old Jan 22, 2010 | 02:34 AM
lol
Old Jan 22, 2010 | 02:58 PM
dex's Avatar
dex
If you eliminate the power steering its going to be much harder to turn than a car that was designed without power steering (like your CRX). The gear ratios in the rack on a car with power steering are lower than one without so you don't have to turn the wheel as much to go to lock.
Old Jan 22, 2010 | 03:12 PM
bentheswift's Avatar
The CRX also had about 1000 fewer pounds on the front wheels. This will make the car painful to drive at parking lot speeds and impossible to parallel park.
Old Jan 22, 2010 | 05:03 PM
I am not deleting it - simply moving the resevoir to the back of the bay next to the power steering pump itself. I just wanted to know what other people have been doing
Old Jan 22, 2010 | 05:25 PM
rangerryda's Avatar
Pics?
Old Jan 22, 2010 | 05:30 PM
btw, youll have to buy longer hose to move it
Old Jan 22, 2010 | 06:08 PM
Do you have any pic of your setup? why would I have to buy longer hoses? Im going to hook it up right where the pump is shouldnt they be shorter? Or does it have to be at the same height in the bay as it was before?
Old Jan 22, 2010 | 07:10 PM
I will post a pic of mine tonight and how installed it
Old Jan 22, 2010 | 10:28 PM
you said you wanted to hide it "behind" the engine.
thats further from where it is in the OEM location.
hence the need for longer hose.
Old Jan 23, 2010 | 12:30 PM
Its closer to the pump making the hoses shorter in my case?? I couldnt take a picture considering my engine is out but I will show a picture when it is complete
Greg S
Jul 21, 2016 07:28 PM
Brimmer555
May 31, 2015 02:31 AM
Zipo
Apr 13, 2015 03:31 PM
