Defi Wire Help
Old Jan 25, 2010 | 06:29 AM
ProMark's Avatar
Default Defi Wire Help
Ok so im installing a defi boost gauge and i cant get power to it idk what wire to tap and there a Red/Orange/white/black wire coming out of the defi power cord. i grounded the black one but im not sure about the others.
RED= ??
WHITE= ?
oRANGE?
Black=Ground
and this Cig lighter wire what color is does anyone have a picture of it and is it a 12v constant or what
i tried searching but i cant really find anything with scion and defi
everything under the hood is ready to go the t-tap to the vaccume hose for measuring boost level
Just no power to control unit so no power to boost gauge
thanks ahead of time im a total wiring noob but i really want to learn how to do
Old Jan 25, 2010 | 07:20 AM
EAmon's Avatar
Sry for not getting back to u earlier. left my phone in my friends car
The wiring should be
Red = Constant power (12V)
white = illumination
orange = ignition
black = ground
Old Jan 25, 2010 | 07:23 AM
EAmon's Avatar
also look here
http://www.egauges.com/Defi/meter_inst.html
that shoudl be what u r lookign for
Old Jan 25, 2010 | 02:42 PM
ProMark's Avatar
orange = ignition
black = ground
Where are the wires i tap?
are they close to the ignition there so many wires
Old Jan 25, 2010 | 05:16 PM
EAmon's Avatar
u can tap the HU wires.
Old Jan 25, 2010 | 05:23 PM
a-mendoza's Avatar
Well if you dont really car about ajusting the illumination, you can just tie the red and white wires together and connect them to a constant 12v source. If your not good with electircal work, just take a volt meter and and check thru your fuses under the dash with the car off and find one that has power runing thru it and tap into it. you can do the same thing with the ignition(orange) wire but this time you want to find a fuse that only has power when you have the key in the on/accessory position. Or you can tap the ignition wire into the power wire for the cigarette lighter. As for the ground, well just ground it.
Of course you can tap into other wires but this is just an example of what you can do that is easy to explain.
Rob54Monty
Feb 3, 2023 08:26 PM
pjl52
Aug 13, 2015 02:38 PM
domincnTC
Aug 4, 2015 01:47 PM
Wrencher
Jul 29, 2015 01:38 PM
semlin
Jul 29, 2015 02:07 AM
