FS: ARC AUDIO Amp Set
Old Jan 25, 2010 | 06:47 PM
Kartel's Avatar
Default FS: ARC AUDIO Amp Set
Parting out my audio system and have a set of ARC Audio amps for sale. They are in great working condition, Selling as a set only!! Price is $250.00. if you are in the greater LA/OC area, you can pick up, otherwise i will ship for actual shipping cost... Heres some info on the amps...
Arc Audio 2500 XXK 2 CHANNEL AMP
# 270 watts x 2 @ 4 ohms, 525 watts x 2 @ 2 ohms, 1050 watts x 1 @4 ohms bridged
# Highly efficient 4 layer PCB
# Rated 250 amp per channel output devices
# Uniquely designed high efficient power transformer
# Variable speed fan control for quiet operation
# Rated 500 amp power supply switching FET
# Heavy duty construction
# Power save mode for low level playing time with engine off
# Protection against: reverse voltage, over voltage, speaker short, and thermal overload
# Signal to Noise Ratio: 105dB
# Frequency Response: 20Hz - 20KHz
# Made in U.S.A
# Dimensions:18"L x 8"W x 3.35"H
ARC AUDIO 4150 XXK 4 CHANNEL AMP
# 80 watts x 4 @ 4 ohms, 160 watts x 4 @ 2 ohms, 320 watts x 2 @4 ohms bridged
# Microprocessor controlled
# Remote digital bass boost gain w/led status display
# Set and forget crossover switches on bottom plate
# Seperate front and rear high/low/full range select switch
# Seperate front and rear mono/stereo/full range select feature
# Thermal, DC, offset, reverse voltage, over voltage, short circuit protection
# Signal to Noise Ratio: 107dB
# Made in U.S.A
# Dimensions: 16"L x 8" Wx 3.35"H
Old Jan 26, 2010 | 06:52 PM
Kartel's Avatar
Lowered price... must sell. starting new project
Old Jan 30, 2010 | 08:36 AM
Kartel's Avatar
late night bumpage
Old Feb 12, 2010 | 08:39 AM
pandapanda's Avatar
Can I buy only ARC 2500XXK? Where are you located? Please let me know by email to hadihartono@gmail.com Thanks!
FrankieD
Scion tC 2G ICE & Interior
12
Mar 20, 2024 10:58 PM
Beesh
Jan 9, 2015 06:30 PM
wizzlexB
Dec 27, 2014 04:06 AM
carid
Nov 21, 2014 11:00 AM
