Custom Stage 0
Old Feb 3, 2010 | 04:23 PM
johnnyb305mia's Avatar
Default Custom Stage 0
looking into a custom stage 0 set up what parts going to be needed in order to run on 6psi with no injectors or f/ic. The reason im asking is cuz i would like to know what manifold and turbo to use i cant find one that will let me run a 16g from the evo 3 that i have just sitting around at the house
Old Feb 3, 2010 | 04:59 PM
cburglb34's Avatar
better get on your knees and bow....here
http://cgi.ebay.com/ebaymotors/DSM-1...Q5fAccessories
makes it so u can use any manifold you want you can even use the ebay manifold that last a liftime and is >100 dollars
Old Feb 3, 2010 | 05:10 PM
trd07tc's Avatar
Have to go the custom route.
scion_andrew's Avatar
U gonna use a intercooler o u gonna do a true stage 0
Old Feb 3, 2010 | 05:15 PM
DezodDon's Avatar
What is a Stage 0 and how does it differentiate from a Stage Eleventy Billion?
God I hate Gran Turismo for doing that to this generation.
Old Feb 3, 2010 | 05:21 PM
no intercooler right off the bat just lookin to have a set up similar to what zpi had. But since zpi went under i will go the custom route
Old Feb 3, 2010 | 05:30 PM
ScionFred's Avatar
Make sure you install wideband AFR and boost gauges and keep the boost/hp low enough for the stock injectors. Also make sure you don't change your MAF tube diameter. One-step colder plugs would be a good idea.
Here is a great manifold for what you're doing:
http://cgi.ebay.com/ebaymotors/Scion...Q5fAccessories
Old Feb 3, 2010 | 05:34 PM
yeah i already have the boost gauge and im going to order the afr gauge prob on fri
Old Feb 3, 2010 | 07:17 PM
U should use the stock airbox an maf holder so it desnt get inaccurate readings
Old Feb 3, 2010 | 07:25 PM
speedy000's Avatar
16g ftw!!
Old Feb 3, 2010 | 08:05 PM
thendawg's Avatar
I have a stage 24.5!!!! - Im with ya - i just laugh every time a ricer talks about getting his "stage 4 turrrbo!!!!" lol I wish no one wouldve ever came up with the whole "stage" nomenclature. Its not a standardized system by any means and is pointless.
Old Feb 3, 2010 | 08:09 PM
davedavetC's Avatar
you mean like your Dezod Stage 1 turbo?
http://www.dezod.com/pd-dezod-s1-scion.cfm
Old Feb 3, 2010 | 08:13 PM
I plan to use my intake that i have right now, i have my own custom intake so i will use the maf sensor adapter and incorperate it in the kit
Old Feb 3, 2010 | 08:23 PM
TCpete's Avatar
this is a recipe for disaster... no inj. no ems. no ic.... motor wont last long on that setup
Old Feb 3, 2010 | 08:43 PM
highvoltage1's Avatar
be careful! It can be done but your treading a fine line!
Old Feb 3, 2010 | 09:23 PM
it wont be with out the f/ic injectors or the fmic for long maybe a month or two if that but im just trying to get peoples in put that way i can safely run this typemof set up but going the custom route
Old Feb 3, 2010 | 09:26 PM
Then why not wait? Seriously a month longer wont kill you. But it could kill your motor if you dont wait.
Old Feb 3, 2010 | 09:29 PM
well i thought that since i have the 16g just laying around and i have the oil feed and return lines the boost gauge im going to order the afr gauge on fri n getting my other oil pan tapped on sat i could go ahead and create my own stage 0 zpi did it y can't i lol
Old Feb 3, 2010 | 09:34 PM
elgueaga's Avatar
will that manifold hold 10 psi
Old Feb 3, 2010 | 09:38 PM
if your talking about the one in the link my boy has an ebay cast iron mani and he is running 10 daily for over a year with no prob
