Help...........How to test stock BOV/BPV
Old Feb 4, 2010 | 04:58 PM
tCZion's Avatar
Default Help...........How to test stock BOV/BPV
Hello!
I see many treads about the S/C stock bov not working when upgrade pulleys for more boost. I have upgrade my pulley many times and on the boost gauge I can see the full boost, but now I change my setup since I build my engine whith forced internals and intercooler with the S/C. I know there is a pressure drop because of the intercooler and piping. Right know I have a 14psi NST pulley and boost gauge tells 10psi that I think is too much drop, I tested the pressure in the intercooler piping up to 20psi and have leaks corrected. I want to know how I can test the BOV to see if there a problem there............Thanks!
Old Feb 4, 2010 | 05:46 PM
draxcaliber's Avatar
what are you using for your BPV? if you are using something like a bosch 102 or 110, yeah, they'll release boost. the 102 release boost above 7-8 psi, and the 110 releases above 10 or so.
you should probably get something like a forge 007 divertor so you can change the springs to regulate the boost it holds.
Old Feb 4, 2010 | 06:17 PM
tCZion's Avatar
Im using the stock bpv.........
Old Feb 4, 2010 | 06:47 PM
wow, i'm surprised you're even seeing 10 psi. that is where you are losing boost. the stock bpv with the supercharger kit is the bosch 102. once a certain amount of boost is reached, it releases any excess boost.
so you need to change out the BPV to something that will hold more.
SloTC1
Apr 2, 2015 07:11 PM
gyiu
Regional - Pacific South
12
Feb 20, 2015 04:20 PM
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
