Gauge install
Old Feb 11, 2010 | 04:16 PM
athletefeet66's Avatar
Default Gauge install
i searched for a bit and couldnt find any good DIYs for wiring gauges. If someone can point me in the right direction or link me to a DIY it would be much appreciated.
A local shop quoted me $175 just for wiring the gauges. I have installed two turbo kits by myself so i should be able to do this as well, right now im just running a boost gauge with no power to it
Old Feb 11, 2010 | 04:25 PM
rangerryda's Avatar
Just tap the power from the cigarette lighter. It'll turn on with the car and turn off with the car. Done deal!
Old Feb 11, 2010 | 04:33 PM
crush02342002's Avatar
^^true true...ther are lots of wires that will do exactly that, just takes a meter to find em. On my houston style thread i had pretty much a diy on aem guage install but its lost someplace in the 100 pages of that thread....lol
Old Feb 11, 2010 | 04:46 PM
what about the little cubby hole light?
my cigarette lighter doesnt even have power to it for some reason
ill try to look through your thread crush
Old Feb 11, 2010 | 04:53 PM
skinnayyy's Avatar
Team Scionara
or use a fuse tap thing. that's what i did for mine. tapped into the gauge power fuse.
Old Feb 11, 2010 | 05:14 PM
Hix's Avatar
Hix
You need to find all of your DIYs and make a Crushtuned DIY thread
Old Feb 11, 2010 | 05:28 PM
lol...maybe. instead of finding them it would be easier to just rewrite em
Old Feb 11, 2010 | 06:05 PM
Prototype_xB's Avatar
Use a test light and find a wire to tap into at the fuse box under the cabin driver's side. A source that cuts on/off along with the key. i did this with my boost and UEGO gauges. Very easy, only power and ground.
Old Feb 11, 2010 | 06:57 PM
05_ScionTC's Avatar
where are those fuses at under the drivers side? and i heard some people of using some under the glovebox too??
Old Feb 11, 2010 | 07:04 PM
there's a panel you remove on the left lower side from the steering wheel if i remember correctly
Old Feb 11, 2010 | 07:07 PM
Scion_42's Avatar
yep. stick your head under there and you'll see a white panel.
Old Feb 11, 2010 | 08:55 PM
05_ScionTC's Avatar
alrighty i will do that, i thought thats what i was but first time i glanced at it didnt really look like it to me.
Old Feb 11, 2010 | 09:31 PM
i need someone to show me then i will know it forever but i will try to tap off the fuse box.
i also need to figure out how to hide the vac line going to my boost gauge....it looks so ghetto
Old Feb 12, 2010 | 04:25 AM
rangerryda's Avatar
I put both my boost and wideband gauges in the cubby and used a doc iso blank panel to fill the void. Everything (wires and vac line) come in from a hole I made in the back upper part of the cubby in front of the bulb. Looks stealth and almost OEM with the matching gauge setup I installed also
Old Feb 12, 2010 | 03:04 PM
asthmatic's Avatar
I would like to see a gauge pic thread
Old Feb 12, 2010 | 05:42 PM
05_ScionTC's Avatar
i agree! x2!
Old Feb 13, 2010 | 02:32 AM
ESEMRFOZZ13's Avatar
wow, my hat off to you (if i wore one) i never thought of that. i have something to wire this weekend, thanks.
Old Feb 13, 2010 | 05:48 AM
rangerryda's Avatar
Anyone else use the cigarette lighter for powering devices and find out that the labeled 12V on the connector is actually ground?? Maybe they jacked mine up from the factory with the wire colors or something...
Old Feb 19, 2010 | 12:34 AM
jsmillie07's Avatar
When ever I have installed gauges I used a fuse tap on the cigarette lighter. I would not bother tapping the wire. It is much easier this way
my06tc
Jun 25, 2015 12:18 AM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
mattjk
121
Dec 22, 2004 10:49 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
