Gauge install
i searched for a bit and couldnt find any good DIYs for wiring gauges. If someone can point me in the right direction or link me to a DIY it would be much appreciated.
A local shop quoted me $175 just for wiring the gauges. I have installed two turbo kits by myself so i should be able to do this as well, right now im just running a boost gauge with no power to it
^^true true...ther are lots of wires that will do exactly that, just takes a meter to find em. On my houston style thread i had pretty much a diy on aem guage install but its lost someplace in the 100 pages of that thread....lol
You need to find all of your DIYs and make a Crushtuned DIY thread
Use a test light and find a wire to tap into at the fuse box under the cabin driver's side. A source that cuts on/off along with the key. i did this with my boost and UEGO gauges. Very easy, only power and ground.
i need someone to show me then i will know it forever but i will try to tap off the fuse box.
i also need to figure out how to hide the vac line going to my boost gauge....it looks so ghetto
I put both my boost and wideband gauges in the cubby and used a doc iso blank panel to fill the void. Everything (wires and vac line) come in from a hole I made in the back upper part of the cubby in front of the bulb. Looks stealth and almost OEM with the matching gauge setup I installed also
Anyone else use the cigarette lighter for powering devices and find out that the labeled 12V on the connector is actually ground?? Maybe they jacked mine up from the factory with the wire colors or something...
my06tc
Jun 25, 2015 12:18 AM
mattjk
121
Dec 22, 2004 10:49 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
