new springs, now a knock...?
Old Feb 14, 2010 | 01:29 AM
FlintC's Avatar
Default new springs, now a knock...?
so i had htechs and wanted to raise my car up a little bit bc ive been scraping the crap out our newly purchased homes driveway and put on some vogtland springs.
drove it around yesterday, pretty spirited for about an hour, 30 minute drive back home on the interstate w/ no problems. come through my neighborhood i take a left turn and out of no where here a knock in the right rear... wtf? so i turn the steering wheel right slolam style and nothing, back left... and it knocks again. i noticed also everytime i hit a bump id hear the knock. so i immediately checked the top 3 nuts in the back and the strut rod retaining bolt and they are all tight. looked up the back the best i could and the end link appears to be fine and the spring appears to be seated fine.
any ideas of what this could be? could i have the spring perhaps twisted a little? im going to pull the tire off tomorrow to put my adjustable endlinks on anyways so ill take a look. by all means i really dont want to have to pull the strut assembly off. what a PITA.
Old Feb 14, 2010 | 02:43 AM
ack154's Avatar
Usually something is loose (top nuts like you checked, endlink is common, etc) or the spring isn't seated properly.
I would honestly just doublecheck every nut and bolt.They may look tight but it really doesn't take much to make a knock when there's that much pressure on them. And if it is mostly when you turn that tells me it is more than likely an endlink thing (from my experience anyway).
Old Feb 14, 2010 | 03:22 AM
RoboCop's Avatar
Agreed, check all nuts again. I just started getting a knock on one of my coilovers. Found out that my top bolt is loose. I could spin it with my finger. Gotta fix it soon.
Old Feb 14, 2010 | 01:16 PM
FlintC's Avatar
cool. thanks guys. bout to go install the adjustable endlinks soon. ill check everything then.
prescottn
Feb 24, 2016 11:57 PM
Itgb
Sep 2, 2015 05:18 AM
AMS13
Aug 20, 2015 07:26 PM
goatbelly
Jul 12, 2015 10:13 AM
Naughtygoose
Jul 6, 2015 09:59 PM
