Header emissions question?
Old Feb 16, 2010 | 01:43 PM
USDM_tC's Avatar
Question Header emissions question?
If i buy an aftermarket complete exhaust(from the header to axle-back) and i get the CEL eliminators for my 02 sensors i know i wont pass the visual part of emissions but will i pass the hydro-carbon part? If this is asked somewhere else im sorry but i cant find anything...
Mike
Old Feb 16, 2010 | 02:09 PM
draxcaliber's Avatar
only if you had a catalytic converter somewhere in your exhaust set-up.
Old Feb 16, 2010 | 02:29 PM
ack154's Avatar
Ya, I think you'd need to make sure it had at least a high-flow cat somewhere in there b/c if you're doing header and back, you're removing two cats.
Old Feb 16, 2010 | 02:45 PM
TunerKid's Avatar
the CEL eliminator tricks the ecu into thinking there is a cat by moving the o2 sensor further from exhaust flow. if youre going that route, i would either keep the stock manifold or put a high flow cat in the midpipe.
Old Feb 16, 2010 | 02:48 PM
my06tc's Avatar
you need at least one cat to pass inspection no matter what....unless you really know the inspector really well and he does you some favors
Old Feb 16, 2010 | 03:35 PM
Mouse's Avatar
Good suggestions here... and the others in this thread too...
Easiest thing I think to do is simply hold onto the OEM header...and when it's time for inspection... simply slap it on go down, pass, come home swap it back out. Hell it only takes 20 mins to have the race header off and OEM back on. Plus the Primary cat is on the OEM header... so one, you'd pass visual inspection, and with it being the larger cat of the two stock ones, you'd have a better chance of passing the actual emissions portion too.
That's what I do and it's pretty friggin' easy. Just my 2 cents
Old Feb 16, 2010 | 06:10 PM
tcnoob's Avatar
or live in Wv like me where there is no emission lol
Old Feb 17, 2010 | 11:59 AM
USDM_tC's Avatar
Lightbulb
alright thanks guys, by the sounds of it ill prob leave the stock manifold replace the top part before the cat then swap out the down-pipe. . sand the whole header down and paint it with high heat black or red or something and thermal wrap it. Ill post pics when i do it.
Mike
Old Feb 17, 2010 | 04:19 PM
Mouse's Avatar
Mike
high temp header paint... cool. Wrapping? NOT cool. dont do it. It will significantly shorten the life-span of the part. Are there short term benefits to doing it? yes there are....that's why NASCAR, and other Pro racing sport teams do it. BUT.... they also have the budget to replace those parts often.
What causes the shortened life-span is that the wrap does not allow the metal to expand (when hot)...and contract (cool down) properly....thus causing metal fatigue by putting stress on the part in a way it was not made for. It also holds in heat longer once the engine has been shut off as well.
Old Feb 17, 2010 | 10:34 PM
BZinn1's Avatar
high heat paint on stock header will do no good,and wrapping stock header will trash the cat in it in a matter of weeks.
either leave it stock or do the header swap back to stock prior to inspection......unless it is the MMW header it takes less than 2 hours to remove and replace and that is with smoke breaks and beer and standing and staring at it.......very easy to do.
Old Feb 18, 2010 | 04:09 AM
Mouse's Avatar
yeah ^^^ agreed...on the header itself...paint probably wouldnt last. But doing the heat-shield is no problem. I did one on my other tC before I got a performance header for it.... I used high temp ceramic paint on it (after prepping the metal for paint of course) and it held up very well.
Old Feb 19, 2010 | 03:39 AM
USDM_tC's Avatar
what i think im going to do is get an aftermarket header and weld in a high flow cat on the mid-pipe and just extend the wiring for the o2 sensors. That way i could get the best performance out of it. i didn't know wrapping a cat would kill it so fast. thought it was safe for it. shows how much i know. just lost my job today so this project might be delayed but ill post up some pics when i do it.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
elzy0000
Jan 16, 2004 04:31 PM
