Need Pics & Measurements of xB with TRD's Please!
Old Feb 15, 2005 | 06:09 AM
bB2NER's Avatar
Music City Scions
Default Need Pics & Measurements of xB with TRD's Please!
Trying to visualize an xB w/TRD springs from the side profile. Also need actual measurements from the ground to the wheelweel lip center for the front and rear. Thanks in advance
Old Feb 16, 2005 | 06:12 PM
bB2NER's Avatar
Music City Scions
The only pics I can find are too dark to see the distance between the lip and top of the tire. Still need pics and measurements PLEASE!!!!!!!?????
Old Feb 16, 2005 | 09:52 PM
itzjere's Avatar
I have xA pictures with TRD springs.. I dunno if it'll be the same, but I'll let you decide that.
http://www.pbase.com/itzjere/lowered
Old Feb 17, 2005 | 06:48 AM
bB2NER's Avatar
Music City Scions
Thanks for the response, but I'm not sure about which pix are before and after. Also unclear if TRDs drop the 2 of them the same amount. Need before and after measurements to get the amount of actual drop. And the easiest and most accurate spot to check is down the center of the wheel, from the ground to the WW lip. Really just need to know if it is 1 inch of lowering like the info I have gotten.
Old Feb 17, 2005 | 06:52 AM
itzjere's Avatar
Those are after pics. Before pics can be found everywhere. Just look at any stock xA. When you compare stock and TRD springs next to each other, you'll notice a big difference in height, mostly from the wheel gap. The TRD's are listed at 1" all around, but after settling, they sit lower than 1". More like 1.5"
Hopefully that helps. If you got any more questions, shoot.
Old Feb 19, 2005 | 07:16 AM
TJ's Avatar
TJ
BEFORE
BEFORE
AFTER
AFTER
Hope that helps. the fronts will settle a bit more with time and it won't have that look as in the last picture.
Old Feb 20, 2005 | 02:10 AM
bB2NER's Avatar
Music City Scions
Thanks TJ, thats what I needed for pics but I still need actual measurments from the Wheel well edge to the ground down through the center of the wheel. Trying to set height to match the TRDs
YooItsJay
Dec 2, 2015 08:13 AM
mark13018
Feb 6, 2015 08:57 AM
snappe2
Jan 27, 2015 05:29 PM
randode
Oct 2, 2003 05:14 PM
