?Raceland CAI = Check Engine?
Old Feb 21, 2010 | 06:08 PM
Leightc2's Avatar
Smile ?Raceland CAI = Check Engine?
So my boyfriend just bought me a cold air intake for my 2007 Scion tC. The intake was doing well for a few days, then my check engine light comes on while I am driving. I am well warmed up and about 5mi out to my destination. The light at this point had stayed on for 2 days. The morning I start to drive to work I expect the light to be on and it never turns on.. then later as i'm driving home from work, it then again comes on while I am driving down the road and has been on since. The CAI was installed Feb 15th.
I went to Advanced Auto, they ran my codes and they said it was my MAF. Its properly seated.. all my connections are tight and my car is running fine, nothing strange about the way its running. Any ideas guys? Thanks.
Old Feb 21, 2010 | 06:22 PM
XIEmperorIX's Avatar
Did you disconnect the battery at any point during or after the install?
Old Feb 21, 2010 | 07:21 PM
TheQuietThings's Avatar
Possibly damaged during install. It is a very very very delicate piece.
Old Feb 21, 2010 | 07:40 PM
FlintMica2005's Avatar
MAF sensor is probably shot.
Old Feb 22, 2010 | 07:06 PM
SeanJohn's Avatar
Yup, sounds like a bad MAF sensor.
Always disconnect the battery.
and handle the MAF with extreme care.
I running the Raceland CAI on my car driven 400+ miles no CEL at all.
Old Feb 22, 2010 | 07:14 PM
ack154's Avatar
Probably this.
You could try cleaning it with MAF sensor cleaner (autozone, etc) or try disconnecting the battery and resetting the ECU if that wasn't done yet. Just be sure to let the car idle for 10-15 min afterward.
Old Feb 23, 2010 | 01:09 AM
Leightc2's Avatar
Smile
Thank you very much guys for the info and advice. We tightened down everything just to make sure... bolts... hose clamps.. hasn't come on in 2 days... so we will see what happens.. hopefully its gone for good! Ill keep you guys posted. Again, thank you!
Old Feb 24, 2010 | 10:42 PM
KFedyszyn's Avatar
All you have to do is diconnect the whole battery and ;let it reset...i had the same problem with mine and it is all good now
Old Feb 26, 2010 | 05:29 AM
Leightc2's Avatar
Smile
Well I thought I was in the clear... didn't come on for a few days. Ill disconnect the batter after work tomorrow, and let you guys know what happens. Thank you!!
Old Feb 26, 2010 | 05:33 AM
RusWolf's Avatar
as someone mentioned, clean the MAF sensor it might help.
Jordly221
Feb 13, 2019 05:29 PM
Miqmiqmiq
Apr 16, 2016 02:34 AM
daniinpitt
Apr 4, 2015 08:07 PM
greytc
Jan 12, 2015 09:49 PM
AdmirN
Jan 5, 2015 10:19 PM
