Changing Rear Brake Pads Problem. PIC Included
So ive done my front pads already. Im changing the rears and there is only 1 caliper bolt, so I slide the caliper up. I took the old pads just fine, put the new ones in and lubricated them and compressed the piston with my C-clamp. And when I tried to slide the caliper back in I encountered this problem shown in pic.
The caliper hits the brake pad. It seems I do have a clearence on the side of the piston. BUt the rear caliper top part doesnt come off completle like the front one, and the top part doesnt go back and forth only up and down. How do I make it fit?
make sure caliper is pressed in all the way. Also the "outer shell" or the piece thats hitting your brake pad can be adjusted back and forth. The pin it connects with you can slide it on.
So try pulling that piece forward and it should move closer towards you and allow you to fit it over the brake pad
DaBlackBox
134
Apr 10, 2022 02:04 PM
TheTripleC
Jan 4, 2015 06:46 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
